Hi,
I'm feeling pretty dumb to be having to ask for help after what's happened.
Earlier today I took off the left crankcase cover from my Yamaha XV250 (Virago). On the Virago the left cover contains the stator.
After putting the cover back on and riding into town, I noticed a terrible oil leak coming from that left side cover.
In town, I took the cover off again and tried to put it on with a better seal. This seems to have slowed the leak a bit, but by no means stopped it.
What makes it tricky is there's a wire which enters the crankcase at the bottom front, and a thicker wire which enters at the bottom rear. The wire at the bottom rear has a grommet, which is tricky to line up.
At the moment, the bike is parked with a bowl underneath the crankcase. Just a couple of hours after my last ride, the bowl already has about 200mL of oil in it.
Can anyone offer any words of wisdom to help me eliminate the leak completely, without having to take the bike to a mechanic and getting screwed.
I'm in Hamilton. If there's anyone there with some expertise and some free time, I'd be grateful if you could help.
Cheers
David
