Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Oil for GSXR-1000 (k4)
    26th May 2015 - 21:48
    2015 GSX1300R Hayabusa
    The manual is helpfully vague - "use 10W-40".
    Synthetic, semi-synthetic, mineral?
    Also, anyone have a preferred brand? I've always used Castrol in my cars...
    5th January 2008 - 10:15
    Tiger 1050/ Racing Sidecar/KX450F
    Taupiri
    I use Putoline Sport 4 10w-40 in my sidecar which runs a modified K4 GSXR 1000 motor
    No Bull Sheds F1 Sidecar Team - Proudly supported by:
    No Bull Sheds - Putoline Oils - Shoei Helmets - Raecin Motorsport - Mad Graphics
    13th November 2011 - 15:32
    '09 Bandit 1250s
    I use elf oils because elf sponsored some speedway series I was a part of. Buy quality, I prefer synthetic (I've tried a couple different oils for a few 1000km, synthetic seemed to help with smoother gear changes).
    Support a brand which is quality and supports a racing series you watch
    9th October 2008 - 15:52
    RSV4RR, M109R, ZX10R
    wellington
    Penrite 5/40 fully synthetic.
    So full synthetic, decent brand (I doubt I'll get brand consensus on here!).
    The manual also says 18'000km between changes. Is this appropriate?
    9th May 2008 - 21:23
    A
    B
    Castrol Activ 4T is what I've used in the past. Mobil 1 full synthetic nowadays.
    Or just ask the bike shop when you fetch an oil filter?
    wellington
    Quote Originally Posted by jonnyk5614 View Post
    Once go fully synthetic don't go back to semi again.
    I would think your reading information about service number 4 at 18k.
    Seems likely oil and filter should be every 6k or 12months which ever comes first.
    If you give the bike a hard life you could reduce that even more.
    Race bike I was doing every 2hrs track time.
    14th July 2006 - 21:39
    2015, Ducati Streetfighter
    I like the full synthetics. Brand is your preference X Y Z.
    Got some Amsoil in presently.
    Don't rate Castrol in my bike (does not shift as well after a few thousand kms) but that's bike specific and I ran it successfully on other rides.
    18,000 kms between changes - on a Suzuki. Best check again they tend to have the shortest oil change intervals recommended in NZ I've seen (6k). Lots of bike makes recommend intervals of 10-12,000 kms.
    BUT
    You will find they also recommend yearly changes as if lower kms the oil still picks up a degree of water over the year.
    I only do about 5k a year and change oil and filter yearly. If I was doing higher kms I'd personally still change the oil around 6k and filter every second change. But I've always been fussy about shit like that and work on the theory oil changes are easy to do at home and relatively cheap. Yeah it is likely I am wasting money but I feel happy with my oil change regime.
    Your choice. Good luck :-)
    A
    B
    Nah, your book should show 6000 kms between changes. Do the filter as well. Personally I'd do 3000 kms on mineral oil or 6000 kms on synthetic.
    Brand names of oil...meh, just pick a decent brand as you said.
    Sorry - my bad. I saw the title "engine oil replacement" and "18'000km" and didn't read the paragraph. Oil and filter every 18'000. 6'000 for the oil....
    wellington
    Price of filter so low you should do every time. Filter not replaced contains a lot of old oil also.
    http://www.trademe.co.nz/motors/moto...-895408041.htm
    That's the K&N that fits in your bike.
    I must do some research on the net - bet Suzuki USA recommend higher oil change intervals than 3750 miles...... I may even put on my tin-foil hat and suggest it is a conspiracy between Suzuki dealers in NZ ...........
    A
    B
    You'll need an armadillo instead, tin foil be no good.
    6000 km oil dump is more or less universal on IL4 Suzi stuff...
    Quote Originally Posted by mossy1200 View Post
    Cheers for that
    Yeah - my understanding of Fully Synthetic oils is that they, technically, last forever. Not like mineral ones where the molecules get crushed over time.
    What you change for is the contaminants that end up in the oil....
