Results 1 to 5 of 5
Thread: Engine/Gearbox Oil
    14th January 2005 - 07:24
    _
    North Shore
    Engine/Gearbox Oil
    my gearbox is notchy/noisey/clunky (yes, its a honda) and i was wanting to change/top it up incase it was running low or too thin.
    after looking through my haynes manual, i cant find anything on gearbox oil.
    so i can only assume it uses the engine oil.
    is this correct?
    thanks in advance, jeremy
    "Artificial Intelligence is no match for Natural Stupidity"
    6th November 2004 - 14:34
    SUZUKI TR50 STREET MAGIC
    it is motor oil but you should get motorcycle specific oil , try supercheap,repco or motomail might be open today. new oil and filter would be best, semi synthetic would be more than enough for your old shitter
    7th September 2004 - 10:00
    A Krappisaki Tractor
    South
    It uses SAE10W-40 standard bike oil I think from memory (check that).
    No separate gearbox oil required, just takes its lubrication from the engine.
    The contents of this post are my opinion and may not be subjected to any form of reality
    It means I'm not an authority or a teacher, and may not have any experience so take things with a pinch of salt (a.k.a bullshit) rather than fact
    15th June 2005 - 19:24
    Its yellow. Sometimes a green one
    No fixed abode
    Spectro Golden 10/40 will help. It is renowned for gearbox and clutch improvements. Must be the additives they use. Retails for somewhere between $45 and $49 dollars depending where you go.
    _
    North Shore
    Quote Originally Posted by TwoSeven
    that is the answer i was looking for, thanks
    but yea, 10w/40 is what it says in the manual. the oil is still mint and gold tho
