Page 1188 of 2720 FirstFirst ... 1886881088113811781186118711881189119011981238128816882188 ... LastLast
Results 17,806 to 17,820 of 40792
  1. #17806
    19th June 2011 - 00:29
    Is it just me, or does it look like the piston is quite a long way down the barrel with no ports yet opening?
    I alreay thought something was weird but couldn't lay my finger on it. guess you just did.
  2. #17807
    Look more to the left the reed entry seems pretty high................doesn't it .....lol
    Attachment 312440 Attachment 312441
  3. #17808
    maybe the combustion chamber in the head is moved up and down within the cylinder?? Has Lennart Van den Doel , had some input to this invention??
  4. #17809
    Simple control of dwell and linear motion.
  5. #17810
    Husa, I'm afraid you caught a bad case of fourstrokingitis. Get well soon.
  6. #17811
    Yes but you have to admit that it would be kind of ironic to use their own popit wigit treachery against them to allow control of the port timing, by proxy.
    I like the old steam engines too.
Size:  10.4 KBClick image for larger version.
ID:	312467Click image for larger version.
  7. #17812
    29th March 2013 - 14:57
    Honda NS-1 / Gas Gas EC-125
    Portugal
    It can be just as the Gas Gas EC125 cylinder/head, the combustion chamber is recessed into the cylinder some 5-6mm, so that can look like it has pretty low timmings, when its just the deck that is not really in the top of the cylinder, but a bit bellow.
  8. #17813
    8th July 2013 - 11:01
    2001, Aprilia, RS250
    Oz
    Frits, are the new/different features of the ryger engine something that could be adapted to other existing two-stroke engines?
  9. #17814
    like this one ? im guessing why the rygar pics looks to have a low piston is because the cylinder bore sits down in the casting which gives the appearance of the piston sitting farther down
  10. #17815
    17th October 2011 - 23:07
    Kawasaki KR150 2007
    Jakarta, Indonesia
    Cool
    Anyway, concerning Ryger engine, I tend to believe the basic concept works like this...
    Just add the cylinder reed and keep the transfer port as a additional mixture storage (& or inlet), leave the pumping/supercharging effect to that cylindrical stuff beside the reed housing, then add another mumbo jumbo details (& connectors) to make it work (stuff that I don't want to think about right now)...
    As Frits said, much simpler, right?
    I think, it really could take some space back from the fourstroker..
    It really could just me mumbling some crap though...
ID:	312475   Click image for larger version.
ID:	312473   Click image for larger version.
  11. #17816
    Quote Originally Posted by pugs View Post
    That's interesting, what are we looking at? LPG transfer port injection?The white thing, pumping bellows?
  12. #17817
    OK, I give in Frits, this game is no fun any more. Back to the open ended sliding sleeve engine I think, just need to make a piston to suit and it's almost ready for a fire up ( with standard reed sysem ).
    If it makes 70HP I'll take some half assed photos, so as you can't quite see how it works
  13. #17818
    Maybe if we all chip in we can pay Frits fine.........
    OK assuming it is simple.
    to increase the cylinder filling if the air is first compressed it takes up less space and can also enter faster.
    Giving some additional time for atmospheric filling to do the rest.
    I have already posted this pic.
    Note how the inlet air flow is continuous, no stop start losing and gaining inertia.
Size:  10.4 KB this is a bigger pic only sideways Click image for larger version.
  14. #17819
    Just add the cylinder reed and keep the transfer port as a additional mixture storage (& or inlet), leave the pumping/supercharging effect to that cylindrical stuff beside the reed housing, then add another mumbo jumbo details (& connectors) to make it work (stuff that I don't want to think about right now)... As Frits said, much simpler, right?
    Your idea looks rather simple compared to some suggestions I've seen here. But your pumping cylinder is moved by crankcase pressure alone, right?
    It may function at 3.000 rpm, but the Ryger revs past 30.000 if you keep your foot down (which I did the first time I gave it some throttle, because I expected 125 cc kart-like acceleration, not the rocket launch I got) .
  15. #17820
    Yep.
    Here are two links showing the standard VM 125-engine.
    VM 125 M 02/B catalogue: http://www.vmmotor.com/www/vmmotor/f...5-m02-beng.pdf
    VM homologation: http://mach1motorsport.files.wordpre...ogering-vm.pdf
    I didn't count them but I estimate that in the Ryger engine 98% of these parts are used unmodified, including the cylinder head.
There are currently 5 users browsing this thread. (1 members and 4 guests)
  1. ranasada
