Frits, may I ask a question too.. It's about port layout/axial-radial angles VS bore-stroke. For high performance engines at least. Say this is RSA's port layout, which is a 54 bore by 54.5 stroke.
Also axial angles are 28-7-52.5 for TFRs A-B-C.
I believe I am thinking this one correct: Radials should form a shape like in the above pic, where Bs' flow collide in the middle of the lower bore half and -pretty much- As' flow surround them, also colliding in the middle of the lower half.
So, if we had a 60mm bore, it's the general shape that should be similar and not the numbers as stated in the pic. Ie the 60mm shouldn't have the Bs at -12/-16, but at -13.3/-17.8. In other words, if someone had to create a similar pattern, he should use the normalized (to the bore) numbers. Yes?
Now, about the axial angles and the stroke.
The 28* (or 7 or 52.5) direct the flow at, say, height
h1 in the cylinder. And it creates the perfect scavenge model.
If we had a 50mm stroke and used 28* wouldn't height
h1' be different than
h1? Then the scavenge model would be less perfect, correct?
I am not sure if this is the correct way to think, it' s static analysis after all. Perhaps the smaller amount of time the 50 stroke has to reach
h1' compensates the difference. And so, radial angle desing might become more universal.
