Page 881 of 2727 FirstFirst ... 38178183187187988088188288389193198113811881 ... LastLast
Results 13,201 to 13,215 of 40897
  1. #13201
    Quote Originally Posted by Nickko View Post
    Attachment 290611
    Still a rough spot at 7000rpm, but likely to be exhaust length.
    I was impressed with your bike, it was very well put together.
    A small adjustment to the exhaust length to see if it can be better balanced with the inlet tract is certainly worth a look, it will only be a matter of a few millimeters.
    The air correction jet may be worth a look to, the rough spot was not so evident with the leaner main jets.
Name:	Fuel Curve.JPG
ID:	290619 originaly posted by Husaburg
    A smaller air correction jet will not lean the main out as much at the top end of the rpm range. So by fiddling the air correction and main jet you may be able to lean the bottom off and keep the top rich.
  2. #13202
    31st July 2005 - 11:15
    a shed full of crazy shit
    Attachment 290611
    Great dyno session on the FXR/FZR tonight. Mikuni TM33, Ross racing Piston and Kelford cams. Still a rough spot at 7000rpm, but likely to be exhaust length. 71 runs on the Dyno with a very patient Rob.
    The air correction jet may be worth a look to, the rough spot was not so evident with the leaner main jet.
    two cents for consideration.
    Close, but looks rich on the pilot circuit, transfer onto the needle (~6.5k) seems to flood things then likely a little lean on WOT.
    Try smaller pilot, slightly thicker needle and keep the main (go up if a size when hole is filled). I don't think dropping the needle will resolve that hole. Refine with the air circuit (just don't starve it at the bottom end).
  3. #13203
    Its a foul stroke guys leave it alone.
    best bit of carb advice is you are both right, as they have overlapping circuits. personally that's why EI and similar carbs are intersting, because they don't.
    this is one of the best bits i have seen.Cameron
    http://books.google.co.nz/books?id=J...ameron&f=false
  4. #13204
    Frits, somtimes a balance shaft is a necessity, I would be frightened to even get off the ground with this engine before the balance shaft was fitted, now I'd be happy to fly all day.
    Neil, I am very much in favour of a balance shaft for almost any engine, regardless of cylinder capacity. What I was trying to say was:
    If you just drive the balance shaft from the crankshaft, the gear friction will consume about 5% of the power needed to drive the balance shaft.
    If you use the balance shaft as a counter shaft, that gear friction will consume about 5% of the total engine power.
  5. #13205
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    Attachment 290611
    i would try a oko 30mm carb for starters . around a 118 jet , drop the needle one from centre , think your will a better base run before going to big in the carb, not a bad run anyway
  6. #13206
    Frits, I might just have to suffer that loss, the reason for running the engine in reverse is handling related not engine related. The reverse cylinder is because I'm sick of dents in my chamber ( not put there by me I might add! ). The difference of 3 - 4 HP at around 70 - 75 total in an off road bike probably won't be noticed, well, certainly I can't use all that.
  7. #13207
    Attachment 290611
    That looks like your classic reversion hole at 7k for sure. I would be looking at the muffler more than length. Looks almost like it has some sort of reduction in the muffler. Or its a megaphone? I have sean plenty of graphs like that trying different exhausts on FXRs.
  8. #13208
    Sand cores multipling in Claire's oven, as time permits, during the day when she is at work.
    Copied the bondi fill transfer core box into metal at the foundry this week end, so now I can make hot sand cores. If I was interested in production I would have made a few more metal die copies but I probably will only ever need 12 transfer sand cores? One casting to machine up first and make mistakes on and the second "real" one.
  9. #13209
    Was given the job of custodian of this engine, aircooled rg125, it was built by Pete Jones, has run but needs some loving.
    Should push all your aircooling buttons TZ. The cooling fins that look like the head are just cooling fins attached to the head beneath.
  10. #13210
    So you going to make a twin? the pipes will be like octopus tentacles. Does the crecy engine like expansion chambers as the RR version only had stubs
  11. #13211
    No, just a single, always a mistake will be made on the first casting!
    Crecy was supercharged so it's quite a different engine. I'm just stealing the open ended sleeve tech, I'm not even using their sleeve drive.
  12. #13212
    aircooled rg125, it was built by Pete Jones, has run ...
    I like it, I have some heavy industrial heat sinks that I am interested in using, thinking of air cooling a RGV250 cylinder that I have had the cases for, for some time. I was going to make a H2O 100 but an air cooled 125 has its appeal.
Name:	Heat Sink Head.jpg
ID:	290674Click image for larger version.
Name:	GP & RGV cylinder plate.jpg
    Just about figured out how to get the heat from the exhaust port area out to the fins. The current idea, is to fill the water cavity with copper wire off cuts and oil and sandwich the cylinder between copper faced heat sinks.
Name:	TF100 RGV 2.jpg
ID:	290672Click image for larger version.
Name:	TF100 RGV 1.jpg
    Using an RGV250 cylinder would give me a power valve and a great cylinder with open access to the transfer ports for fuel injecting.
    The EFI thing is part of getting these air cooled projects reliable.
    And there is an even more challenging but exciting follow on project in the wings, so plenty to do.
  13. #13213
    9th October 2012 - 14:55
    CBR/FXR
    Thanks Rich, the muffler is a CRF250 - straight through.
  14. #13214
    Cool. Have you ever had it apart? I had a Yohsi pipe that was straight through. But it had a little ring in the middle to push air around into the second perf. I removed the ring and the second perf and what do you know. No more reversion hole. Also you could try dropping the bottom of the Header 2-3mm from the bottom of the port (mismatch the port to header). I have also done this and it seams to be an improvement. Leave top and sides of the pipe flush or a tiny bit bigger than the exhaust port. Or of course it could be something different. my 2 cents.
  15. #13215
    Does that apply to smaller engines as well?
There are currently 7 users browsing this thread. (1 members and 6 guests)
  1. DSE
