Results 16 to 30 of 31
Thread: Please help. Issues tuning XR400 Carb on FXR150
  1. #16
    Get a 2 stroke and all of your (current) problems will be solved.
    Yes you will never have to check valve clearances again, your engine maintenance/tuning will be simplicity itself......
  2. #17
    3rd June 2007 - 18:11
    miWhodeXD
    GB
    Hey guys, appreciate all the ideas. I agree with most of what has been said and suggested. Some great ideas on things to check out.
    Developments this evening:
    Problem 2 now solved!
    I timed the drop from 12k revs down to idle and it was up to 8 seconds! I tried connecting a rubber band to the throttle drum to add more power to the return spring and the problem was solved . It only takes about 1.5 seconds to return to idle now. So, even though the throttle slide always returned fully with no hesitation when the throttle was tested and the bike not running, when running I presume the air pressure (or something) added a bit of resistance and the spring was struggling to close the throttle. I also now must admit that I caused this problem as I had bent the spring a little to make the throttle a bit lighter! I had fully tested that it returned firmly every time so had dismissed it as part of the problem. I can tweak the spring back and live with a heavier throttle .
    I took the bike for a ride and problem 1 still exists though I can just control my right hand and it goes OK. I have ordered 2 smaller main jets and will test it with them. I think that will help, as Rick suggested. The plug is not all sooty but on the road test it was still slightly rich.
    Thanks for all the suggestions.
    Damien
  3. #18
    miWhodeXD
    GB
    These are clasic symptoms of being lean at the bottom. If this was my bike, (a 2-stroke) I would think it was lean on the pilot jet or slide. When they are lean here they just go flat when opening the throttle before picking up and then the engine takes a while to settle back down again to an idle when the throttle is closed. If you were riding it, it would run on for a bit when shutting off and entering a corner.
    I think a 4-Stroke is probably much the same and its lean at 1/8 throttle..............the pilot jet..
    Hi TZ350. Yes, I have had lean issues before and it did have those symptoms but no pops or backfires and no lean plug. It had me totally confused! Thanks for the input.
  4. #19
    miWhodeXD
    GB
    Hi my carb is a xr 500 I was running a 137 main but Tim got me a 135 when he got one for himself and it runs really good now Tim has smaller carb but that also runs great with the 135 . They say get the main good first then work down to pilot I did plug chops to get it close a good colour on the plug.
    Hi Rick. Sounds like good advice on reflection. I started the other way around! Mt Welly should be great for plug chops. I'll work on it.
    Hey, had a look back and found an old photo . I am still shocked by how fast you came past me at Taupo in practice - even though I had carb probs!
    Regards
    Damien
  5. #20
    miWhodeXD
    GB
    Quote Originally Posted by timg View Post
    Could it be that the XR400 carb is simply too big? From what I can understand the quick FXR's (& wannabe's like me) down here are using GN250, XL/XR250 or DR250 carbs. The DR250 flat slide is supposed to be the business
    You could be spot on! I like flat slides. My CRF250R has a 37mm flat slide - I must try that .
    Appreciate your feedback.
    Regards
    Damien
  6. #21
    miWhodeXD
    GB
    Hi Damien
    Have you got any room to ride it. Have a read of this might help. http://www.iwt.com.au/mikunicarb.htm
    It could be a little big. Is it over 28mm?
    Hey Richban, great link and info, thanks. Yes, it could be too big. Rick has made a big carb work. I'm already close. I think it is worth working on. I need Mt Wlg to test it. Appreciate your advice.
  7. #22
    miWhodeXD
    GB
    Quote Originally Posted by DangerousBastard View Post
    Yeah, but he's also got a sooty plug.. Is there ever any backfire with the hesitation? If there is, then it's lean for sure, and maybe the sooty plug is indicating rich on the (midrange) needle.
    Can you try a good long cruise on the open road with a new plug? Stay well away from full power and thereby well off the main jet, and see if you still have a sooty plug. Also vigorously try and provoke it to hesitate, and see if you can make it do a lean backfire.
    Does it start easily with no enrichener? Steve
    Hi DB. The sooty plug is not an issue now - see original post. I have not had any backfire or popping issues - so I was totally confused too! Your approach is sound - thanks. It starts perfectly and idles well. I think leaner on main jet will solve. Will be in touch.
    Thanks
    Damien
  8. #23
    20th September 2008 - 12:50
    XT660r
    Quote Originally Posted by Damien_Toman View Post
    Hey Buckets4Me, the FXR is the first 4-stroke I have ever raced. Just seemed to be the right bike for starting in bucket racing. I plan to have my 1987 RD350LC YPVS ready for racing this year. I used to race the original 1983 version when it first came out. I raced the older RD250 air-cooled before that. All 2-smokes! I'm sure Rick will provide his expert view on FXR carburetion.
    Look forward to racing you in postys on the YPVS Damien, and in buckets now that I have got one(RX125) and just bought a TF powered FZR250 for my son
  9. #24
    And if it blows up it won't cost a million bucks to fix!
  10. #25
    24th July 2008 - 18:01
    Honda RS 125 1992
    Taupo
    Cheers Damien nice clear pic :,)
  11. #26
    bike seemed to be going ok (well he went past me with a bit of steam)
  12. #27
    miWhodeXD
    GB
    Hey guys, thanks for all the suggestions and feedback. As Buckets4Me says, it was not too bad at Mt Wellington after I changed the needle back to the middle position (3rd from top). I did that after my 2nd practice session on Saturday. It reduced the bogging issue and increasing the idle also helped minimise any issues. As you might detect from the photos, I was loving it! I now need to do more dirt biking to build up fitness!
  13. #28
    miWhodeXD
    GB
    Can you 100% be sure that the inlet manifold is not leaking?, an easy test is simply to spray something like breakcleaner or easy start around the inlet manifold rubber when it is idling, if you find that the idle increases immediately, there is every chance that there is a manifold leak.
    Another option is to check you valve clearances.
    On a hotted up four stroke, there is a good chance that the valves are getting a hard time, simply because of the increased RPM.
    If this is the case, and the valves, particularly the inlet, can, quite often stretch, closing up the clearance.
    And, if so, this will cause the bike to run lean, and quite often "spitback" off idle.
    Of course, there are other symptoms that will cause this to happen (carb problems mostly), but it is something I would check before spending any more time on the carb.......it only takes an hour at the most to check your valve clearances, and at the very least eliminates this as a cause!
    Hi SS90. Good thinking. I've had lean issues in the past with my CRF250R when the right inlet valve tightened up - a common problem. I did check the manifold and it was very tight - sound. I will check valve clearances before the next race.
  14. #29
    miWhodeXD
    GB
    Quote Originally Posted by RDjase View Post
    Hi Jase. Indeed! I've still not started on the RD350YPVS - looking forward to sorting it out. Yes, keen to ride with you on buckets - I must say that the FXR is so much fun to ride that I'm not even in a hurry to sort out the YPVS - but I will get her back into action.
    Regards
    DT
  15. #30
    miWhodeXD
    GB
    I'm sure he will to
    and the fxr is probably the BEST bike to learn on
    pitty I got a 2 stroke as a first bucket (well a second but I sold the cb125t before I got to race it)
    the fxr is easy to get to grips on
    also I have an rd400 in parts that I was building to race but havent got around to it since racing buckets (buckets is way more fun and cheaper)
    I like the old yamaha 2 smokers
    Those old air-cooled RD400's were incredible and scary. I would love to test ride one today. Great bikes. One of my old mates had one.
