I've done a couple of engine oil flushes with diesel fuel and even rode the bike around the front yard somewhat. The engine warmed normally and I could not detect any difference with the engine running on engine oil or diesel fuel (as a lubricant.)
I would strongly suggest you did not open 'er up on the open road doing this. Either only idle it, or else ride it very quietly around the yard, or maybe venture around the block on it. Total engine running time maybe about 20-30 minutes, 3/4 of that time idling in neutral, and the other 1/4 puttering around at very low throttle levels while exercising the gearbox.
I would have no real concerns doing another diesel fuel flush, provided precautions were taken.
Again, there was no detectable complaint, noise, or otherwise, from the engine at any time. The engine sounded just like it had proper oil in it.
edit: dont put any oil additives of any type in motorcycle engine oil.
Steve
"Wow, Great advise there DB."
