Results 1 to 15 of 15
Thread: Need help with rusty spokes & info about Fuller dremel machine thing
    26th January 2008 - 07:37
    91 R80GS
    The spokes on my new to me BMW R80GS are really rusty.
    Anyone had any as bad as these & if so did you manage to get them halway decent.
    http://i710.photobucket.com/albums/w...ustyspokes.jpg
    Also I bought one of these to see if any attachments would work better than green scourer or steel wool ( which I've been told not to use but nothing works as well)
    http://i710.photobucket.com/albums/w...yobidremel.jpg
    I tried these attachments but the wire wheels seem just to polish the spoke not cut thru the rust. The grinding wheel I used very briefly & lightly but wasn't that appropriate.
    http://i710.photobucket.com/albums/w...ttachments.jpg
    ANy better ideas?
    Also after they're at an ok stage what is a good treatment for them - fish oil? or similar
    Thanks in advance.
    3rd September 2004 - 08:51
    05 iHornet 900
    Westham
    A daily dose of CRC 5.56 Penetrating Oil for a week will minimise breakage
    ANy better ideas?
    CRC Marine 66
    Thanks in advance.
    What are you trying to achieve ..... Best you define "to get them halway decent"
    If you want them nickle plated you will need to dismantle the whole wheel and take the wire brushed spokes and nipples to the plater.
    Could order some new spokes and nipples and get them relaced.
    In my mind !!
    .. That is going to be the most cost effective ........ best result ..sadly it would be expensive...
    1st December 2005 - 23:59
    MOTARD
    NZ
    maybe look at > http://www.wheelandspoke.co.nz/services.html
    Spokes: Custom Made Sets - Stainless From $175.00
    Eagals may soar but weasals dont get sucked into jet engines
    4th October 2007 - 14:25
    whatever is going
    3rd rock from sun
    Quote Originally Posted by Sam I Am View Post
    What he said.Also,what is the condition of the rims?May have to bite the bullet.
    13th April 2005 - 12:00
    Enfield cr250r
    Tokyo
    Honestly wheels arnt that difficult to re-lace , look on internet for instructions
    if you go slow and number mark each one the tension as per instructions ( I can help if needed ) youll be fine
    I welded up a jig and clamped a dial gauge to it , and as the wheel is assembled measure any offset ( internet) and bobs your uncle
    The first one is a learner , but after that , you will be buying hubs and rims separate from then on
    Stephen
    28th May 2006 - 19:35
    suzuki
    lower hutt
    get a chain drive bike, then the chain lube will keep the rust away
    oh my word.
    ok the pic is low res, but it looks like there is some severe pitting going on. to make any difference you'd have to turn ~1mm off the dia Clearly a dumb thing to try. Have to admore your optimism with the dremel. But they are a great tool, used carefully they have 100s of uses
    I'd go further to say I'd replace those as a matter of course esp if you intend to ride the bike off road, or if the bike had any appreciable power or weight, which clearly it doesn't & does in that order.
    suzuki
    lower hutt
    I've got an R80GS and have had cracks in teh rim from spoke holes, check carefully for these too
    9th June 2009 - 08:23
    76 HONDA XL125
    SOUTHLAND
    I have been cleaning up some spokes using some green abrasive synthetic wool (spokes only it will destroy chrome) but mine aren't as bad as yours. Its slow work so if your impatient or your time is valuable then a new set of spokes is probably best way, plus you get a chance to polish the hub properly before its laced.
    I'm using Autosol metal polish on the spokes after cleaning off the rust its very good on rims as well.
    "Your talent determines what you can do. Your motivation determines how much you are willing to do. Your attitude determines how well you do it."
    -Lou Holtz
    91 R80GS
    Ok sounds like I may add spoke lacing to my set of averagly adequate skills.
    cheers
    3rd January 2005 - 11:00
    All of them
    Brisvegas
    I would replace them for safety. Only needs one to snap from that sort of fatigue and it can get ugly real quick.
    30th July 2008 - 18:56
    Road King
    In the sun.
    These spokes look stuffed, very pitted and corroded. I don't think you will get the nipples off without problems. Time for a new set if for no other reason than safety..
    91 R80GS
    Cheers guys. I won't waste my time trying to clean them then.
    I'll order a set.
    MOTARD
    NZ
    rember to still price them from http://www.wheelandspoke.co.nz as well as bmw
    91 R80GS
    Will do. thanks for the link.
