Results 1 to 7 of 7
Thread: How does this work? Laminar Flow Engine
    25th April 2009 - 17:38
    RC36, RC31, KR-E, CR125
    Manawatu
    so this shit is pretty cool, anyone guess as to its operating cycle? (I read the full article so will know if you're right too )
    6th June 2008 - 17:24
    The Vixen - K8 GSXR600
    Behind keybd in The Tron
    There's tiny imps inside it, pedalling treadmills...
    Quote Originally Posted by slofox View Post
    Yeah .. that makes more sense ... Some people will try to tell you it runs on sound waves .... but it's actually something like this ... if I can remember my physics from last century ...
    The gas inside the tube is heated, expands and pushes the piston out ... as the piston moves, the pressure inside the tube drops, and the air cools, assisted by the heat sink (the lumps/clamp around the tube) creating enough vacuum that as the flywheel comes around, it pushes/sucks the piston inside the tube, pressurizing the air, which heats up from pressure ansd the candle .. and around it all goes ...
    It will run on just the wire mesh, which is right at the candle -
    That's a very up-market one. Bet he didn't make it himself ... it's something kids can make in a garage ... at least they did before Playstation ...
    18th May 2005 - 09:30
    '08 DR650
    Methven
    The twin's cool ... I wonder what the energy in vs energy produced is like ? It could be pretty efficent.
    3rd April 2010 - 16:22
    2000 Aprilia RSV Mille,
    ChCh
    In theory it is possible to achieve afficiency equivalent to the Carnot Cycle. In reality the best achieved is around 40%.
    Since the twin is air cooled with no significant regenerator I'm guessing 15 - 20% at best
    Manawatu
    build quality on the quad rocker is excellent, I'm thinking bout putting a v8 one together (4 middle cylinders hot, end ones cool). Anyone got ideas for making the cylinder and pistons real good, metals, needs rings? etc
