Results 1 to 9 of 9
Thread: Parts for 1982 Yamaha XJ750
    7th April 2009 - 12:39
    1994 Kawasaki EL250
    I have (and in the process of rebuilding) a 1982 yamaha XJ750, I need a full gasket set and piston rings and was wondering if anyone other than TP Chch would be able to provide these items??
    Distributor of Uncle Garrys cushions for Uncle Flips Kickers (or should that be knickers?!?)
    Cleverly disguised as an adult! D.N.B.W and newly est Grease Monkey
    3rd March 2008 - 11:55
    ST2 NZ250
    The evil flatlands
    I got the piston kit and gaskets for my XL from budget motorcycles, aftermarket rather than oem parts, seem to be working ok so far. The rings for my scooter came from cliff bonds, I think they do gasket sets as well.
    The other yamaha dealer is bob mcleary out at rangiora, but I'm guessing they'll probably be the same as TP.
    1994 Kawasaki EL250
    I've already tried Budget, they didn't have them which is a bugger, still I have a friend in the UK who might do e a big favour....
    Where is Cliff Bonds?? Ok, found them! Looks like they are next to TP!
    Last edited by KiwiPhoenix; 3rd November 2010 at 11:58. Reason: Like you Neels, need to learn to read properly!
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    (PostalDave on ADVrider)
    4th November 2003 - 13:00
    BSA A10
    Partsnmore http://www.partsnmore.com/parts/yamaha/
    Before you go ahead with it, why do you think it needs rebuilding?
    does it go?
    have you done a compression test?
    If you do strip the top end you would need to measure piston to bore clearance before you buy the rings, if there is to much you would need pistons as well
    While the head is off pay some attention to the valves as well
    Ebay is your friend when building old bikes, as these were sold in the USA there should be plenty of bits for them, also Chacal on XJbikes is a good source
    Quote Originally Posted by KiwiPhoenix View Post
    They are the other side of Fitzgerald ave from TP and about 1/2 way to Durham st heading towards the centre of town, I've used them for a few things and they were very helpful
    1994 Kawasaki EL250
    Cheers for the advice guys! The bike was burning oil and also had a few oil leaks. The piston chambers have just been honed, the place that done said it looked in reasonable nick for it's age!
    I'm going to get the valves done and I still have a few other things to check, but getting there slowly but surely.
    does it go?
    As previous owner ... I have told her most of the above ... second opinions are popular and appreciated ....
    1994 Kawasaki EL250
    As he said
    Thanks
    13th January 2004 - 11:00
    Honda PC800
    Henderson -auckland
    Theres a bloke on here who is about as much of an XJ nut as I am. From memory he had a complete barrel/piston ring set ready to go into the old seca 750.
    I missed where the oil leaks were etc but I would have been looking closer at the condition of the valves and the faces as Kickaha advised. Often theres more compression lost there than in the bores.
