So, put the bike (Yamaha SRV250) back together and no neutral light, no start. Indicators, headlight & horn all OK.Turns out the plugs in the headlight cluster weren't as idiot proof as I assumed; in the process of a bit of a re-furb, I have transposed a couple of plugs (I think maybe the right & left control plugs).
I check the fuses and the 5 amp ignition plus 15 amp head & signal fuses have blown. There were no problems before I disconnected everything and pulled the headlight out to treat rust.
I've checked continuity to the best of my limited ability & cleaned connections. Suspect I have melted a component such as cut-off relay or igniter unit.
Is there a "most likely suspect" in this scenario?
Thanks in anticipation.
Bruce
