Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Oil for a two-stroke engine?
    2nd March 2011 - 20:43
    LML Belladonna
    Hello
    I purchased my bike (2009 LML Belladonna) just a short time ago - about to put oil in for the first time. Owners manual says simply put in two stroke oil. I duly purchased some, semi synthetic as opposed to mineral. Some one I spoke to said "Oh no, don't use synthetic - you MUST use mineral". Now I am left wondering what to do...is using semi synthetic going to damage my bike? Should I only ever use mineral?
    Thanks in advance for your help...
    30th July 2008 - 18:56
    Road King
    In the sun.
    It's fine, what flavor was the oil?
    4th February 2005 - 07:32
    Rattlecan blue
    What flip said.
    Have heard people recommend mineral for four strokes for the first x km but that's more about getting the gearbox run in properly and doesn't apply to two stroke engine oil.
    You'll also get people saying don't mix mineral and synthetic but thats is also nothing to worry about, a hold over from the days of bean oil which doesn't mix with anything.
    13th April 2005 - 12:00
    Enfield cr250r
    Tokyo
    Mixes with milk!
    Any good quality ( mobil , bp etc ) will be fine
    The only bad experience I have had is with cheap ( Suzuki) scooter oil
    I used it in me MX bike gave it a spanking and did the bottom end ... my bad ,
    Dont worry about things to much
    Synthetics with higher specs delay wear a bit more.
    Stephen
    Scooters coming back in fashion !! I have a geonio cub and its great for zipping round town
    Stephen
    17th April 2006 - 05:39
    Various things
    Not quite right sorry mate. In a four stroke, it's more about getting the rings to seal against the cyl wall. Two and four stroke gearboxes are pretty much the same, cept a four storkes oil does the engine as well as the gearbox. Gearboxes don't need 'running in', and modern engines don't really either.
    Do not mix synthetic and mineral oils either. Especially in a two stroke.
    Enfield cr250r
    Tokyo
    Quote Originally Posted by Crasherfromwayback View Post
    Can you expand on this as Im with Henk on this one ...
    Stephen
    Various things
    Quote Originally Posted by Brian d'marge View Post
    Stephen
    Which part in particular?
    Road King
    In the sun.
    Back in the old days when the performance 2 stroke oils were castor oil based they were not missible with petrochemical oils, hell they were hardly soluble with petrol. But now days the synthetic's are simply non-polar hydrocarbons that are perfectly soluble with any other non-polar hydrocarbons.
    Nobody would make a oil that was not soluble in other manuifacturers oils. These oils still have to comply with the SAE requirements for 2 stroke motor oils.
    Various things
    Quote Originally Posted by Flip View Post
    There ya go then! I always thought it was more some of the additives etc in the oil that caused problems mixing. Glad I don't have to worry what I use in my dirty old RM400!
    13th May 2003 - 12:00
    Thinking
    Around
    Synthetics ? what is a Synthetic oil people?
    The Manufacturers now call Hydro Cracked group 3 oils Synthetics, which of course they aren't by the original description of what a Synthetic oil is, i.e a PAO (polyalphaolefin), smoke and mirrors now have the market (you guys) believing a group 3 is a synthetic.
    p.s a synthetic is compatable with a mineral or a semi synthetic, it wont matter, however you will be reducing any advantage that synthetic oil has over lesser spec'd oils.
    LML Belladonna
    Thanks and one other question...
    Hey Guys
    Thanks for all the tips, I really appreciate it. I get the feeling I should choose one type or the other and stick to it.
    At the risk of seeming like a completely naive noob....I got this masport branded stuff. Masport in my mind is only for mowers, but it did say I could use it for the type of engine I have (only exlcuded use in some marine outboard engines). Should I disregard the brand name and just use it or go with a more recognised brand like Shell or something?
    And yes its heaps of fun to ride, talked my workmate's ear off this morning when I got to work
    Road King
    In the sun.
    Masport won't make the stuff, its probably Mobil or Castrol oil. Given mowers are a low stress low power motor I would suggest the oil will be a basic old fashioned pre mix 2 stroke oil.
    The wrong oil is better than no oil, but modern oil are very clever and technical.
    26th April 2008 - 00:01
    KTM 950SM, '78 X7, FZ750, GN250
    Don't use masport shit. Don't use any store brand stuff or oil you get from a gas station as it will foul up your engine. My favourite cheap oil is Spectro Golden semi synthetic. Don't bother with a full synthetic for your scoot, it's a waste of money.
    4th December 2008 - 18:50
    Anything with trainer wheels
    with ya mumma
    But are they as easy to de coke as the mineral based ones?? (serious question as have always been under the impression they arnt) Even if you are running 2 % less by volume.
    Rattlecan blue
    I'd steer clear of the masport stuff, but from gut feel not science.
    The other thing to be aware of is to make sure you get an oil that is specified as suitable for oil injection. Some of the premix only oils are great but are too thick to go through an injector stsyem properly. Have used motul 600 (now called something else) and Castrol TTS with no problems, not the cheapest you can get but done for peace of mind, used them in both oil injected dirt and road bikes with no problems. Suspect your scooter may be a little lower stressed but don't know. Also suspect that if you buy a four liter pack of something decent it will see you out the rest of the year.
