Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 94
Thread: Help. VT250 has water in oil?
  1. #31
    Quote Originally Posted by MSTRS View Post
    Would seem so. Of course, the question is...what is his mother tongue? IlliterateArrogantMoron?
    That is open to speculation ... and could be the start of a whole new thread ...
  2. #32
    10th December 2005 - 15:33
    77' CB750 Cafe Racer, 2009 Z750
    Majorka'
    Maybe English is his second language - how many can you all speak/write?
    I love the smell of twin V16's in the morning..
  3. #33
    Quote Originally Posted by jonbuoy View Post
    SPEAK/WRITE ... ???? get with-it we TEXT .... so does he obviously ...
    ATTITUDE gets you further than some/ONE may think ....
  4. #34
    17th July 2005 - 22:28
    Dougcati, Geoff and Suzi
    Banjo town
    94
    Honest.
    Bling your bike out!
    PM me
  5. #35
    9th June 2009 - 08:23
    76 HONDA XL125
    SOUTHLAND
    I've noticed good threads go for 2/3 of there total length before they cave in and die the rest about 1/4.
    Pity really I was interested how the engine was going to turn out.
    actungbaby, just carry on. Criticism is just like a bend in the road in this place....get your lines right, pass through it then your set up for the next one.
    "Your talent determines what you can do. Your motivation determines how much you are willing to do. Your attitude determines how well you do it."
    -Lou Holtz
  6. #36
    30th July 2008 - 18:56
    Road King
    In the sun.
    Quote Originally Posted by ZXCharlieR View Post
    Hi mate,
    Place a large magnet on the cylinder top and with fine grade metal powder you'll see if it's cracked anywhere as it will show.
    Magnetic particle inspection only works on ferrous alloys. It relies on making a N and S pole across the crack. Since alloy heads are not magnetic this will not work.
  7. #37
    76 HONDA XL125
    SOUTHLAND
    Quote Originally Posted by Flip View Post
    where do you place the magnet in relation the the suspected crack on ferrous metals?
    I've never seen it done before so I was thinking I could play around checking for cracks in an old frame before its painted.
    -Lou Holtz
  8. #38
    Road King
    In the sun.
    Across the area you want to crack test.
  9. #39
    76 HONDA XL125
    SOUTHLAND
    Cheers, I found a vid on youtube.
    http://www.youtube.com/watch?v=ek6U1vWRU-A
    Didn't know circumferential was a real word either......
    -Lou Holtz
  10. #40
    11th June 2011 - 16:30
    Honda vfr 750 fn 1992 x2 90red
    palmerston north
    hi people sorry about me loosing the plot
    well quick update , after longish break trying fix xbox 360
    I checked one conrod and moves quite bit side to side not good
    So am going take the engine apart , just need some help
    does anyone know if the fly wheel bolt is right or left thread i thought it
    have to be oposite to way thing spins for safety . and dont want break it trying to undo wrong way .
    overall the engine is easy to take apart damm dispointed that seems pretty knacked though looks like paid 600 for chassis and wheels
    Quote Originally Posted by Spearfish View Post
  11. #41
    Banjo town
    I cannot remember which way the flywheel bolt goes and my VT250 owners manual is on another computer
    Chances are, it's a normal threaded bolt and may have a locking bolt in it too, but, try down load a manual for it and you'll be fine.
    As for one rod moving like that, have you taken the rod off? It shouldn't move side to side.
    Both rods should be on one single crank pin, side by side.
    PM me
  12. #42
    palmerston north
    Thumbs up
    Thanks so much again your replys always learn from them
    yes i think they are side by side , and that was without undoing anything
    so that why i know i got strip it down more, no use puting back toghter like that
    i doubt it run and if it did it probley blow up or make some nasty sounds
    i actaully pushed on piston and it clonked and moved
    be cool to get copy of the manuall i tryed looking on the net and found nothing
    i tryed buy one also with no luck .
    for me getting fly wheels of is like mission imposible with no fly wheel puller
    but always managed last one on xr 200 engine fell of bench and put hole in crank case but managed to get it welded and fixed aghhhh
    i used car jack and wire wraped around to tension it
    i been offered a second hand crank so assume i need at least one new connecting rod as well if not two , i think the boring that is expensive on these motors
    being cast as one piece , but just see howe it goes before making a descion
    as is i get some enjoyment from taking it apart, maybe neraly many hours as good ps3 game ;-(
    thanks
    mate
  13. #43
    Banjo town
    Quote Originally Posted by actungbaby View Post
    thanks
    mate
    I'd try find another motor, the machining on it alone would cost more than it's worth
    Load this up; http://www.pdfasal.com/auto/1989-hon...rs-manual.html
    Should be helpful.
    PM me
  14. #44
    palmerston north
    thanks got that one was really cool esp about the general stuff like choke
    etc nothing on the engine though
    Should be helpful.
  15. #45
    palmerston north
    Thumbs down
    omg i reached in and moved the end of con rod on left one and you can see rock
    back forth like 3 mm and make clonking sound that is stuffed must broken bearing shells no wonder found bits metal in the sump
    this is in direction for the piston so wonder it didnt snap of compelty
    under the pressure of the combustion forces shhhh
    damm is it running old oil does this sort damage dam
    Should be helpful.
