Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
Thread: Two-stroke bike won't start - help
  1. #16
    13th May 2003 - 12:00
    Thinking
    Around
    I fixed it thanks all
    Ive run out of fucks to give
  2. #17
    The R1 taking it's name of course from it's predecessor the YR1
    http://www.classicyams.com/brochures...brochures.html
    in 1967 a far more ground breaking machine & if course more advanced even now as having the correct number of strokes. Almost 45 years ago & hp/litre hardly progressed.
  3. #18
    17th July 2005 - 22:28
    Dougcati, Geoff and Suzi
    Banjo town
    Did you do a skid Quasi?
    Bling your bike out!
    PM me
  4. #19
    30th May 2003 - 21:22
    Walking
    I would have said drain the 98 and use 91 octane. Can make quite the difference.
    Keep it in mind if troubles persist.
    Racey
  5. #20
    Thinking
    Around
    Quote Originally Posted by Racey Rider View Post
    Racey
    really 2 strokes run better on lower octane ?
  6. #21
    Walking
    Competition two strokes would have reason to run higher octane If There Motors Are Built For It!
    But your talking Moped.
    Unless it's had compression work done, or spark advance, it's designed to run on 91.
    91 will certainly help it Start easier as the flame front burns faster.
    and if the motor is old, it's propabley down on compression anyway.
  7. #22
    Thinking
    Around
    Ok, well there hasnt been any mods done to it at all, its a TOPFUN branded scooter (yes chinese but looks decent quality)
    I filled it up with 98 for the young fella perhaps that wasnt a good idea, as since then the problem started !
    engine has done 5000kms to btw
  8. #23
    Quote Originally Posted by Quasievil View Post
    NO, no, no you're not concluding the thread yet surely! No-one has been insulted about their heritage/choice of bike/religion yet!
    Here is my 1st bike experience;
    1, buy an old run down RT360 yamaha.
    2, test ride to be sure it goes
    3, get it home and ride it for about 10 min until it stops
    4, spend weeks trying to restart the thing, where everynow and then it will fire out the exhaust with a huge long blue flame. Alternately it will kick back like a bastard, jarring every joint in your 14yr old leg
    5, finally get up enough courage to start removing things to establish cause, starting with carburettor and culminating in flywheel where;
    6, find that flywheel to crank taper fit is more worn than a hookers g string. This has in turn caused the woodruff key, and subsequent replacements, to shear to the point where someone has had to loctite the flywheel on. So it has been revolving bit by bit on the crank meaning that timing is out but every now and then it comes right round again to the point where it fires up briefly or is in the right place to fire up a flooded exhaust pipe full of petrol, scaring, literally, the living shit out of the chooks!
    7, by now the cheese like structure of the kickstart shaft housing is worn and starts to crack rendering the whole lot into the parts bin.
    Oh joy!
    NEXT!!!!!
  9. #24
    7th May 2010 - 19:43
    2004 SV1K
    Dunedin
    Im not going to repeat myself Bret..
  10. #25
    Thinking
    Around
    Quote Originally Posted by DrunkenMistake View Post
    It aint mine its the young fellas and spec wise it was better than anything else he could find for his money
    bikes great, its just a small issue (same that happen with anything)
  11. #26
    15th February 2005 - 15:34
    Katanasaurus Rex
    The Gates of Delirium
    bikes great,
    Keep telling yourself that Brett.
    You should be able to convince yourself for at least the next two weeks.
  12. #27
    9th May 2011 - 20:23
    AX100
    JaffaLand
    Hmmm. But is it triple stitched?
    Buy cheap shit, expect it to break. Cant remember who told me that.....jog my memory for me will ya please?
  13. #28
    2004 SV1K
    Dunedin
    Quote Originally Posted by jaffaonajappa View Post
    Didnt you have a whinge about Trolling?
    Uhh I mean make a thread.
  14. #29
    Thinking
    Around
    If you emptied your house out of chinese made products how much would be left smart arse?
    however, it has better brakes and better rubber than the Yamaha Jog and the Suzuki thing, the Honda seemed overpriced.
    So yes the bike is a better deal and was a better over all spec than the jappas, had more storage also and better seat.
    Headlights are brilliant so Im happy with the young fellas purchase.
    There is no problem now, but I will get the carbs checked out tomorrow.
  15. #30
    Thinking
    Around
    Yeah thanks, I will take it to a mechanic tomorrow to get the carbs checked however I know Mechanices are over priced under skilled idiots, but I will risk it.
