Originally Posted by
Fast Eddie
haha, thats a new one..
I recon that will overtension it if anything, the tensioner will extend out a bit as u slackin off the bolts and now when u bolt it back down its going to be extended further than it should be and if its working properly it may not back itself off and stretch your cam chain or destroy the tensioner even faster - or if the tensioner is already stuffed this wouldn't make a difference the tensioner will just back off as soon as the engine starts running.
you can however use a long bolt and turn your auto tensioner into a manual tensioner for about $2 dollars for a pack of nuts n bolts of the correct size.
you can google how to do it, it was easy as for the blade.. or pm me for rough instructions. its bloody easy, you don't even have to remove the tensioner from the bike. (im referring to my blade anyway, dunno what your bikes setup is like)
oh and if you get further into this, and have tried a few tensioner fixes.. replacements modifications whatever and the noise still persists it is quite possible you have to replace cam chain.. they do stretch and apparently quite easy. mine did, good news is for me anyway the cam chain was waaay cheaper than replacement tensioners
