Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: Akunar parts FXR?
    5th November 2007 - 14:46
    BMW
    hamilton
    Akunar parts FXR?
    Im want to make my FXR engine a bit quicker, im aiming for around 200hp but if I get 10% of that id be happy...
    These Akunar parts seem good, im thinking a new piston, exhaust, cams, valves and a carby from them. I have heard people having problems with the pistons but I will leave the standard rev limit so hope they will be ok.
    Is it the Pro R piston I need? What size pins and deck height? What size valves do I order??
    Has anyone tried the cams?
    I will get someone to port the head for me
    http://www.akunar.com/
    if you only want 10% then you dont need to worry about the bigger valves, the cams seem to work, not sure if you need the proR but maybe you do !, just ask for a 64mm raider 150 piston
    7th February 2009 - 17:47
    93 kwacker zxr750
    palmerston north
    Wink
    think the cams are not as good as stock
    17th July 2005 - 22:28
    Dougcati, Geoff and Suzi
    Banjo town
    I've got a 95mm piston here...and a few longer throw cranks from GN/DRs. Nobody will know.
    Bling your bike out!
    PM me
    Some of my cam data - Akunar is the winner for duration and lift, clearly too much exhaust.
    Standard FXR
    in lift 6.95mm
    ex lift 6.1mm
    valve timing @1mm lift IVO 0 BTDC
    IVC 42 ABDC 222deg
    EVO 24 BBDC
    EVC 3 ATDC 207deg
    Kelford Cams
    in lift 7.78mm
    ex lift 6.63mm
    valve timing @1mm lift IVO 16 BTDC
    IVC 39 ABDC 235deg
    EVO 42BBDC
    EVC 9 ATDC 231deg
    Akunar Cams
    in lift 8mm
    ex lift 7.6mm
    valve timing @1mm lift IVO 20 BTDC
    IVC 60 ABDC 260deg
    EVO 57BBDC
    EVC 17 ATDC 254deg
    Had a pair of the GPR cams up here recently but the guys were in such a rush to put them in I didnt get any measurements.
    93 kwacker zxr750
    palmerston north
    Standard FXR
    in lift 6.95mm
    ex lift 6.1mm
    IVC 42 ABDC 222deg
    EVO 24 BBDC
    EVC 3 ATDC 207deg
    Kelford Cams
    in lift 7.78mm
    ex lift 6.63mm
    IVC 39 ABDC 235deg
    EVO 42BBDC
    EVC 9 ATDC 231deg
    Akunar Cams
    in lift 8mm
    ex lift 7.6mm
    IVC 60 ABDC 260deg
    EVO 57BBDC
    EVC 17 ATDC 254deg
    Akunar Cams
    dont seem to bad after all but need to see the hole read out. will post a read out of the yoshy grind tomorrow
    Interesting - first time I've seen this comparison. Have to say that Kelfords are the only ones close to what I'd consider correct lobe centers. Most of the 600 fours run best around 102/104...
    akunar are coming into the lift area I'd consider reasonable too.
    On balance, without seeing Crazy's Yosh figures, I'd try the Akunar on 102/104 centers....
    Well as I no longer have an FXR the infos all up for general viewing. The centrelines of the Akunars were in part dictated by valve to piston clearance and as the bike made 20hp first run on the dyno there seemed little point in machining the piston to get them closer to where they should have been. Akunar provides zero set up data so it's suck it and see.
    YZF600 kit - in 8.8mm 262deg 22/60 109 centre, ex 8mm 250deg 55/15 110 centre - but then its reving to 16k. This and running the akunar numbers through Lotus le software (with exhaust and inlet data) influenced where the akunars were set.
    BMW
    hamilton
    Good information, thanks guys! Is the bore a cast iron thing that I can bore out to oversize or does it need to be sleeved?
    4th November 2003 - 13:00
    BSA A10
    Quote Originally Posted by CHOPPA View Post
    Cast and you can replace the sleeves
    BMW
    hamilton
    What size valves do i need?
    Inlet Valve OD
    Exhaust Valve OD
    Valve Length
    Valve Stem Width
    24.50mm 22.00mm 82.00mm 4.50mm AKV24228245
    24.50mm 22.00mm 85.00mm 4.50mm AKV24228545
    27.00mm 23.00mm 65.50mm 5.00mm AKV27236550
    28.00mm
    24.00mm
    65.00mm
    5.00mm
    AKV28246550
    28.00mm
    24.00mm
    72.00mm
    5.00mm
    AKV28247250
    28.00mm
    24.00mm
    80.00mm
    5.00mm
    AKV28248050
    30.00mm
    26.00mm
    65.00mm
    5.00mm
    AKV30266550
    30.00mm
    26.00mm
    72.00mm
    5.00mm
    AKV30267250
    30.00mm
    26.00mm
    80.00mm
    5.00mm
    AKV30268050
    31.00mm 26.00mm 72.00mm 5.00mm AKV31267250
    31.00mm 27.00mm 72.00mm 5.00mm AKV31277250
    31.00mm 27.00mm 80.00mm 5.00mm AKV31278050
    fxr150 valves
    in 2 x 23mm, stem 4.47 mm
    ex 2 x 19.75mm, stem 4.45 mm
    CRF150 for comparison
    in valve 2 x 26 mm
    ex valve 2 x 22.5mm
    IVO 15 BTDC
    IVC 48 ABDC 243deg
    EVO 50 BBDC
    EVC 25 ATDC 255deg
    inlet valve centreline 106.5
    exhaust valve centreline 102.5
    and the ported FXR inlet with 28mm carb is good for 120cfm. I'll miss the old 4 stroke
    BMW
    hamilton
    Whats the most important bit I have to match up when sizin? Length of Valve and Stem size? Then find the suitable valve..
    6th August 2008 - 09:18
    FXR150 Bucket, RM125
    My god. Why not just do cams and porting and leave it at that!? Can't have you getting more HP than me mate or I might have to start crashing more... or God forbid spend more feckin money on my bike.
    BMW
    hamilton
    No point taking the head off twice mate
