Ride it to Te Puke and I'll have a look at it for you
I would:
Check, adjust, lube chain.
Check for play on the output shaft
Check the clutch hub and bearing.
Check the steering head bearings
Check for end float on the crank (if it has any, you'd certainly know about it)
Listen for valve noise
Carbs out of sync can make some interesting noises too
Drop the oil and pick up screen and check for sneaky little bearings floating around...
If you're getting piston slap you'll have a fair amount of blow by on a cold leakdown test
Fortunately we can rule out cam chains as it hasn't got one and a stripped tooth on one of the gears doesn't seem to happen
