Page 11 of 458 FirstFirst ... 9101112132161111 ... LastLast
Results 151 to 165 of 6865
  1. #151
    why not just get a really big aircooled head off say a MZ250 weld up the combustion chamber and machine one that suits your engine. i think you are really going to struggle with the fan thing . I was looking at a fan at work today that would probably do the job but it was 1.1KW 3 phase. Think how big the fan at the dyno is and thats just for short runs.
  2. #152
    Using a head like you suggest is a good idea. It would be interesting to test a fan cooled CPU heat sink. Any ideas how to conduct an experiment?
    Thomas has found a piece of 1.2mm copper sheet at work and as I have a 12mm alloy spacer under the barrel he suggested replacing it with one made out of a stack of copper fins and a heat resistant block so that I wind up with some more finning for the barrel and a heat blocking spacer at the bottom so that the crank case runs cooler for a better incoming charge density.
    As the clutch gets a real caning he also suggested an oil cooler for the gearbox like they have on auto trans gearboxes.
  3. #153
    If F5 gets away without one you sure as hell don't need one.
  4. #154
    Some sort of constant heat source applied to the combustion chamber or whole base of the cylinder head(s) and a fan blowing over the head. Measure the head temp. The better the fin system is at dissipating heat the lower the head temp will be. It'll be interesting to see what effect varying the air flow will have.
  5. #155
    Your right, I can't claim to be making much more HP than him if any and he realy does cane that clutch, thats one real fast 50. How long does that engine last between rebores/overhauls?
  6. #156
    23rd January 2004 - 12:00
    ninja 250
    Probably easier just to move down to Christchurch, don't think anyone was too concerned about an overheating head at the last Battle of Buckets? However fitting heated handgrips might be worth considering?
  7. #157
    We could kill two birds with one stone. Convert to 100cc, watercool the motor, route the coolant through the handlebars.
  8. #158
    ninja 250
    KA CHING!!!
    Brilliant!
  9. #159
    Bucketeers realy are clever people. I like the idea and if I crash will that make me a snow goose? Sorry F5.
  10. #160
    20th November 2002 - 11:00
    Wellington, New Zealand,
    Has anyone one tried machining small horizontal fins on the sides of the vertical fins. More surface area without greatly increasing the cooling path.
  11. #161
    3rd May 2005 - 07:22
    2005 Custom Moped
    where the sun sets
    Had your bike running today it's going great. I am ashamed to say the problem with it was all my own fault and pretty much what you predicted. Glad to hear you survived today.
    sound like you need a ballast resistor to stabilise voltage Maybe if something was set up to come on a a certain number of revs to burn off excess current
  12. #162
    Thats very clever, hadn't thought of that, it's all about surface area, now your got me thinking.
  13. #163
    29th October 2008 - 22:29
    CBX750
    Mt Eden
    I can see that us four strok boys are gonna have to do a lot of work to keep up with the sort of things your talking about on here.
    Either that or we're gonna have to do a lot of talking to keep up with you guys........
  14. #164
    Quote Originally Posted by Sideways Sam View Post
    start talking they are way ahead of you there
  15. #165
    Got the makings together for a new super Head.
    Its going to be a very special head made from a large block of alloy, off cut of copper sheet and an extra heavy section of heat sink.
    The plan is to sandwich the copper between the alloy block and heat sink for extra rapid heat dispersal to the outer parts of the heat sink.
    The finished head will be about 4 times as heavy as the original GP125 head.
    With all this alloy and copper, this has got to be the real deal, RIGHT. WRONG! Wrong! wrong! very very wrong as it turns out.
    Another counter intuitive thing, bigger should have been better.
    When Thomas saw what I was up too he nearly wet himself laughing.
    Then he explained to me that Suzuki was not trying to save money by having a relatively small amount of alloy around the combustion chamber.
    He said the Suzuki head is made thick enough for strength and for the combustion chamber shell to provide an adequate thermal path for the expected heat load. And thin enough so the thermal path to the root of the cooling fins is as short as possible.
    Its for this reason that most air cooled 2 strokes of that era used ½ inch reach plugs and Ύ inch reach plugs were mostly used in the water cooled motors to allow more room for the water jacket.
    If I was to make a head out of the block of alloy like I intended it would be able to absorb a terrific amount of heat energy but relatively too slowly to keep the combustion chamber cool.
    There might be more fin area but the cooling fin tips would probably run cooler (cooler is less efficient at shedding heat) than the original Suzuki head. And the heat path would be to long and the combustion chamber would over heat (or at least be a lot hotter) even though there was more thermal capacity and fin area in the bigger head.
    Its that the cooling bit will be to far away from the fire bit.
    He suggested we continue to use ½ inch reach plugs and cut the alloy block down and mill steps in it so that cooling fins of copper (copper conducts heat away twice as fast as alloy) can be fastened to the alloy combustion chamber, shell as close as possible to the source of heat.
    Even better would be to make a thin combustion chamber shell out of beryllium copper (for strength) and easy-flow copper cooling fins to it.
