Page 125 of 458 FirstFirst ... 2575115123124125126127135175225 ... LastLast
Results 1,861 to 1,875 of 6865
  1. #1861
    Quote Originally Posted by Brian d'marge View Post
    I have an article on the design of belmouths using CFD can try and post it if needed
    I do love those Yamaha SDR frames ( cheap as here) , I think ( not sure that they are a bit flexy ,might be ok with the power of a bucket )
    Just suspension then ,,,is there any internals that can be modded ?
    Stephen
    Hi Stephen I would be interested in the bell mouth design article. The SDR's frame looks the business, did they handle Ok with the 200 motor? This one is from Japan I think and looks like it has been raced, lots of lock wire, or is that a Japanese boy racer bling thing?. The suspension is long and soft. Can you tell us any more about the SDR's in Japan.
  2. #1862
    Thanks, that would be great.
    I was testing some different head designs yesterday (and today), and accidently fitted a head that (I would have thought) was totally unsuitable, as the uncorrected compression ratio measured at 10.6:1 (and 2.3mm head clearance)
    Rather than taking it off, just for interest, I ran it up on the dyno, and the power is neigh on identical to a cylinder head with 13.4:1 (after playing with the ignition)
    I'm not sure what this means just yet.
  3. #1863
    13th April 2005 - 12:00
    Enfield cr250r
    Tokyo
    yes they are raced http://page5.auctions.yahoo.co.jp/jp/auction/e96755106
    I havent tested those frame but I have heard they flex , but thats with a 20 30 hp motor and spindly soft forks
    I did see one of those frames on line quite cheap awhile back
    I would love to draw one of those frames and load it up on the computer and see what it does !
    Stephen
  4. #1864
    Thanks for the pic.
    Could this be what Chambers next Bucket will look like?
  5. #1865
    . . .I do love those Yamaha SDR frames ( cheap as here) , I think ( not sure that they are a bit flexy ,might be ok with the power of a bucket )
    Yeah they look cool & are sort of bucket sized & open enough to take a range of engines. I was eying one up as a mate had one bare with sw. Quick loft, urgh use 2nd hand. Golly! Heavier than they look.
  6. #1866
    About 13 years ago, I guy I worked with thought the same thing. He used to race 125's as well, and threw a set of old slicks on it, and went out on a few laps, the damned thing tied it'self in knots the first corner, man they are flexy frames!
    Put some road tyres back on, and all was well.
  7. #1867
    In other words Dave, they are shit piles
  8. #1868
    Ok the GP-Plenum Chamber is ready for a test ride.
    Pic-01 it's ready
    Pic-02 look who else has come to see how it goes...Friends of Thomas's...they bet against me in the sweep stake........bastards.
    Pic-03 a quick push and it started right up.........starts real easy.
    Pic-04 a short punt up the drive, drives well but falls flat over half throttle, hope its just jetting.
    Pic-05 it even idles.........hows that.
    If I can sort out the flat spot, its of to the dyno next week.
  9. #1869
    May I suggest at the very minimum some sort of generous front mudguard?
    A heavy layer of grease on the castings will hopefully attract any grit/stones that make their way in, or at least tell you how much it is attracting..
  10. #1870
    Yeah. . . but kinda cool looking shit piles in a minimalist lattice frame retro sort of way.
  11. #1871
    5th January 2009 - 19:25
    RS/GP125
    Waitakere City, Auckland
    Pic-01 it's ready
    Pic-02 look who else has come to see how it goes......they bet against me in the sweep stake........bastards.
    Nice work Rob. I must admit I was a bit sceptical. Did you have the helmet on when you fired it up.?
    Will see what the dyno says, hope its the start of good Hp.
  12. #1872
    Quote Originally Posted by Ned Kelly View Post
    Yep.....didn't wan't Thomas's friends to see my red face if it blew up.............
  13. #1873
    16th November 2009 - 14:57
    cbr,streetstocker
    auck
    i should of worn my helemt when i binned my bike on the drive-way in the wet.........
  14. #1874
    a quick push and it started right up.........starts real easy......it even idles.........hows that. ........
    Starts easy and idles, two things that I didn't think it would do well, congrats on a real novel idea that's past it's first test with flying colors.
  15. #1875
    OK,, well done so far Teezee..... I too didn't expect it to idle so well!
    The "flat spot" however, I expected (and I guess you did too).
    We have discussed the inlet resonance etc neigh on a year ago...... I suspect we will be back to that.
    how much "stand off" (amount of fuel/oil mixture) is coming out the carb when you are in the "flat spot" you mentioned?
    Looking at your picture, I was making the assumption that the "wonderful gloss" you new engine had looked a little like it was caused by the "stand off" spraying over the engine.
    Am I wrong in this assumption?
    If it is though, no jetting will fix that, only finding a solution to the resonance this plenum has.
    Nice legs by the way!
