Page 207 of 458 FirstFirst ... 107157197205206207208209217257307 ... LastLast
Results 3,091 to 3,105 of 6865
  1. #3091
    24th July 2008 - 18:01
    Honda RS 125 1992
    Taupo
    Yep I am taking the RS for a splash around ..I hope the weather will be dry at some point over the weekend..
  2. #3092
    5th June 2008 - 17:46
    going by metservice saturday is the best chance of dry whether.
    will have to wake up in the morning and check the weather string.
  3. #3093
    Attachment 226307Attachment 226306Attachment 226303Attachment 226305Attachment 226308Attachment 226302
    One week to go before Taupo and this is where I am at.
    The engine vibrates real bad and I need to re-balance it.
    As there is no one universally "correct" balance factor, there is only the one that works in your bike and it has to be found by trial and error.
    Engine frame and suspension all affect how much you feel the vibration given off by the crank. The likely range of ballance factors that will work well with a high speed 2-Stroke seems to be in the region of 50% to 65%
    Check out the quote for info on working out ballance factors and how to change them.
    Yum. I have a bit of a thing for old lathes, that one looks lovely.
  4. #3094
    It belonged to Chambers Dad and that makes it a bit special. The lathe is called "Mr Rattley", and its been very useful.
  5. #3095
    V belt & tool post! Makes my Sheldon look old fashioned.
  6. #3096
    10th December 2008 - 07:39
    07 fz6n. 07cbarrrr600
    STRAYA
    The owner of my race bike, Chris has a wee Southbend on his bench, now that thing is neat.
  7. #3097
    Ok got it going, I had problems with the new cylinder, it had been bored for a 0.002" interferance fit, instead of clearance on the piston.
    So I got onto it and linished the piston down 0.004" to fit and with the new re-balanced motor all assembled and in the bike.
    This is where I am upto now.............
    Attachment 226434Attachment 226438
    Tried each of the centre section inserts in turn.
    Attachment 226437
    The RS chamber (red line) with a 60mm mid section insert compaired to my old 21+ hp GP125 (blue line)
    Attachment 226436
    Power went up and the curve moved to the right as the pipe got shorter.
    Attachment 226435
    Blue line is where I am now, 23+hp, not shabby for a hand linished piston, so I guess I got the cam and taper right.
    I havent finished with the pipe yet but I think whats left of the dip in the cammel hump will be able to be pulled out by increasing the inlet duration and dialling in some ignition curve instead of the straight line I have been using for testing the pipes.
    More to do but it looks like it has 23+ hp potential and a 3-3.5K wide power spread.
  8. #3098
    STRAYA
    Ok this is where I am at now.............
    The end of the sentence ?
  9. #3099
    there is still time to come up with another plan and pull it all apart AGAIN !!!
    Last year I had 18.5 h/p
    Ned Kelly had 20
    TZ350 had gearbox problems and around 20 h/p
    Chambers had a 22h/p 100 (that threw everyone off that got on)
    Speedpro failed to get the gearbox working as well
    now it look like I'm not riding
    chambers is watching
    Ned Kelly has 10% more H/p
    and TZ may or may not have fixed the gearbox and 15% more power
    Speedpros bike has been tested and is around 30 h/p
    bring on Christmass I say
  10. #3100
    Well that is quite impressive for a GP125. Bit scary revs for a GP crank thou.
  11. #3101
    This is where I am at now with my bike....... only days to go.
    Attachment 226720
    Testing has stoped for the day,......... slipping clutch at 11ish.
  12. #3102
    Attachment 226720
    Just test it changes gear properly this time huh TZ?
    so thats 30% more H/p in a week !
  13. #3103
    Crank:- RGV250 rod kit with silver plated big end cage and rod side play set at the little end. Double row, self alligning phenolic caged main brgs, light weight KX ignition flywheel.
  14. #3104
    Hardouts!
  15. #3105
    TeeZee's bike.......
    Thomas has cured the clutch slip and they are now getting 27+hp from an aircooled 125 with a legal 24mm carb.
    Attachment 226841
    Three Times Past.......
    Fuel Fog appears in the bellmouth of TeeZee's carb as the engine gets up on the pipe.
    Can those that said three times past does not happen explain where this fuel mist in the bell mouth comes from when the engine is up on the pipe if the air mass is not moving back and forth in the inlet tract and passing the main jet at least three times like TeeZee explaind it would on a well tuned bike.
