Page 225 of 458 FirstFirst ... 125175215223224225226227235275325 ... LastLast
Results 3,361 to 3,375 of 6865
  1. #3361
    Get it right guys - the 125 KZ2 kart engines make 44RWHp = around 50 crank at 13000 with a 30mm restricted carb,pump gas and a straight line ignition.
    The issue with the aircooled I believe is the basic technology available, if it was allowed to use aftermarket cylinder castings with super sex ports/ducts, that equal those in say a RGV250 for example, then its easy to build a rocket.
    The bmep is lower in the 125 size cylinder, making the same power as a 100, so the 24mm carb would not be such an issue.
    But if the carb restriction was lifted, then a serious relook would be needed.
  2. #3362
    I was chatting to JC yesterday and it sounds like the carb restriction for aircooled 125s is close to being a thing of the past. I mentioned to him that it generally wasn't considered to be a handicap now but I didn't get the impression he was going to stop the change. He sees the restriction to air-cooling as being the limiting factor which I think TZ would agree with.
    He had some interesting thoughts on the "fast" FXR150s and cited figures from other quick 4 strokes.
    How is it up to JC to stop or not stop this or any rule change? I thought there was a process that involved putting in a remit to your club and then the club decides wether or not to take it to the MNZ or ACU agm.
    Please correct me if I am wrong.
  3. #3363
    2nd September 2005 - 17:48
    '08 zx6r, GP125, '76 T140V
    Whenuapai
    All he has to do is submit it through the AMCC then, i'm sure no-one will complain if the playing feild is levelled slightly.
    Sorry Officer - I wasn't speeding, i was qualifying...
  4. #3364
    Quote Originally Posted by CM2005 View Post
    What do you mean by levelled slightly? TZ350's GP makes 27hp with a 24mm carb. There is only a handful of H2O 100's that make more. That sounds 'level' to me.
    Just because other 125'ers have not had the same success with their bikes doesn't automatically mean the rules should be changed to make it easier.
    Also, if the presant carb restriction is, as others are saying, not the limiting factor for the 125 aircooled bikes, then why bother changing the rule at all. Quote from Wobbly 'But if the carb restriction was lifted, then a serious relook would be needed'... Yeah no shit!
    TZ350's bike 27hp with 24mm carb, obviously more hp with no carb restriction.
  5. #3365
    17th November 2002 - 11:00
    dam.. i move too much
    there is always ONE who needs more power than anyone else..... unfortunately I also fall into that category
    what a ride so far!!!!
  6. #3366
    4th November 2003 - 13:00
    BSA A10
    That's because you're a fat cunt, lay off the pies and you wont need as much HP
  7. #3367
    Whenuapai
    me too, i need power to make up for my riding inadequacies.
  8. #3368
    How is it up to JC to stop or not stop this or any rule change? ....... Please correct me if I am wrong.
    I don't think your wrong, but things may have changed a little. After MNZ has received a proposed rule change from where ever, competitor or club, they talk with people recognised as knowledgable in the area, if it sounds sensible then MNZ list it on their web site for input and comment after that things could change or be left as they were depending on feedback.
    I guess MNZ have been talking to JC about a suggested rule change and he could back it or poo poo it depending on how he sees it. JC probably won't be the only one they have talked with.
    Anyway something like that..................
    MNZ's compition rule change policy:- http://www.mnz.co.nz/download/Compet...nge_Policy.pdf
  9. #3369
    Double ditto, me too ........
  10. #3370
    And what was so interesting. Did he mention its really hard to get much more than 160hp per liter of on a air cooled 4 stroke single. The only rule change should be for the 4 strokes. Bigger bigger bigger.
  11. #3371
    they had the last rule change our turn now
  12. #3372
    Yes, 4 stroke 145cc changed to 150cc which is why buckets is as popular as it has ever been.
  13. #3373
    i'll take a 5mm change 24mm to 29mm carb
    if it wasent for the fxr150's it would be a lot easier for the 2 strokes to get threw the traffic to the frount
  14. #3374
    yep easy if you swap it for a cbr150
    JC having been involved with racing cbr150's in aussie has mentioned that the fxr dosent stand a chance against a developed cbr
  15. #3375
    Not seen a fast one yet. Bike that is.
