Page 236 of 458 FirstFirst ... 136186226234235236237238246286336 ... LastLast
Results 3,526 to 3,540 of 6865
  1. #3526
    25th February 2007 - 23:37
    2010 CB600f & a couple of bucket RB's
    Check the size of the rotary valve ports
    Attachment 230305
    My GP will have an inlet port that looks like this soon .......
    And I have an idea how I could make a variable port where the closing point can be changed, much like a blade power valve.
    I didn't know an engine could just consist of carbs and exhaust. Do the carb restrictions still apply?
    Yes 4 strokes are for homos. Homo-sapiens that is, who have realized bigger is better.
  2. #3527
    Quote Originally Posted by all4A50s View Post
    125's are still restricted to 24, some doubt about the legality of oversized carbes sleeved back to 24.
    But I have other carbs, pumper and plug/slide that meet the spec by any definition, that I can run if needs be. One flows more than the unit I am using now.
  3. #3528
    4th February 2005 - 07:32
    Rattlecan blue
    No carb or cooling restrictions on 100s
  4. #3529
    I got a 29hp engine on triple-r-superbike dyno, the clutch was slipping bad and it was sucking in gearbox oil so i am sure there is a bit more power, i was running a 33mm vmx carb but am going to try a 28mm pwk carb, i have fixed the clutch with a new kit and added stronger springs, also fixed the oil issue with new seals and more GOO around the rotary disk cover. Its running a cr125 ignition which i want to replace with a zeetronic so i can make use of the powervalve and sort a good tune out.
    I had a look at the www.FXR150.co.nz site, and see there are one or two more very fast 2-strokers in the pipe line down south and a bunch of very interesting FXR's.
  5. #3530
    Cri..st I was feeling cocky untill I saw your bike ...........
    Of more concern is Bren is a pretty shit hot rider into the package. If Nigel can get himself fit & willing to ride 100% & Bren can get his sorry arse up to Taupo it would be a race worth watching.
  6. #3531
    I got a 29hp engine on triple-r-superbike dyno, the clutch was slipping bad and it was sucking in gearbox oil so i am sure there is a bit more power, i was running a 33mm vmx carb but am going to try a 28mm pwk carb,. . .
    Betterer & betterer! I'd be searching around for other carbs to try, space is an issue on the old Joe, but with some case shaving & moving the inlet a bit it'd be fun to try a 34 or 35mm. Wonder if some of those short bodied MX125 carbs may fit in & work well. PWK35 is quite a size up from the 28. FCR conversion are too downdraft. . .hmm.
  7. #3532
    8th April 2005 - 23:14
    Joe2 the ALMIGHTY
    cheers Dave - ahhhh so i should be going biggerer!! Mike has as cr125 carb laying in some dust, i think its 35mm or even bigger?? , maybe i can borrow that for testing! actually i got a rg400 carb too, what you rekon???
    oh kinda stealing this therad a little. sorry ESE
    yippeeee
  8. #3533
    yippeeee
    Been trying to find the flow figures for the 32pwk on the FXR. I think it was close to 124 cfm 32hp ish. So a PWK33 might be a good option to try. The difference between the 30 and 32 on the dyno was 1.4 hp at the top nothing in the middle. The head will flow 32.5hp. Note sure if that helps but them pwks flow well. Old TM 28 Mikuni 110cfm max potential 27.5hp no good to you.
  9. #3534
    yippeeee
    Steel the thread all you like
    as long as there are pictures and stories to go with it
    the tread is all about making a fast 2 smoker for the TRRS
    and sharing idears around
  10. #3535
    I certainly reckon its worth trying, assuming your inlet is ok for it.
  11. #3536
    Flow tested some carbs today. Thomas made up a manometer, which proved to be very effective at measuring flow through the carburetors.
    Thomas made the manometer from some clear tube an old tape measure and some din rail and filled it with anti freeze and it worked a treat. He's a clever fellow is Thomas.
    Attachment 231890 Attachment 231889
    There are a number of posts here about Thomas and TeeZee's method of measuring which carbs and modifications flowed better.
  12. #3537
    Attachment 231898
    Putting TeeZee’s 1978 Suzuki GP125 29.9 rwhp (33hp at the crank) into perspective.
    Attachment 231895
    Suzuki RT63 1963
    Engine type: Air-cooled 123.70 cc twin cylinder rotary valve 2-stroke. 25.5 ps/ 12.000 rpm.
    Bore x stroke: 43.0 x 42.6 mm
    Carburetor type: M24
    Compression ratio: 8.8:1
    Top speed: 184 kph
    Clutch type: Dry multiple plates
    Transmission: 8 gears
    Tyres: 2.50-18 / 2.50-18
    Brake type (front): 2 drums, 1 cam
    Brake type (rear): 1 drum, 1 cam
    Attachment 231896 Attachment 231893 Attachment 231894
    Honda MT125R Hondas 1978 over the counter 125 Racer. The tuned versions were 23-25 rwhp (26-28hp at the crank)
    Attachment 231892
    29.9 rwhp from a tuned learner bike dating from the late 70’s is not all that bad.
    And better than the Honda factory was doing with their own 125 aircooled racer from the same period or the Suzuki factory GP aircooled racer from the period of factory Grand Pix competition in the 60's.
  13. #3538
    Quote Originally Posted by bren_chch View Post
    the bike.... And engine finished
    i like it!!!
  14. #3539
    I would actually like to send all my spec/info to wobbly and see if he has any ideas on what else i could do to make it better.
    Holly crap Assuming your motor is peaking at 13000rpm that gives you a BMEP of approximately 11 bar, that is some phenomenal backyard engineering that you should be extremely proud of
  15. #3540
    Joe2 the ALMIGHTY
    yow ling had a carb or two laying around so i borrowed them, will tell him later!
    I thnk i have lucked on something again, not sure what but i need to go back and see what i changed when i rebuilt the motor, or maybe its just the clutch is actually working 100%, engine seems a lot stronger, but i did widen the inlet and and added a bit more advance on the timing, engine seems to pull harder... that is when i dont bog it down off the start.
    uploading a little driveway test to youtube now, will add to thread after dinner.
    Attachment 231949Attachment 231950
