Page 271 of 458 FirstFirst ... 171221261269270271272273281321371 ... LastLast
Results 4,051 to 4,065 of 6865
  1. #4051
    20th October 2010 - 20:59
    Rg50 Fxr's150
    Dave Mullins is a name I haven't heard for years and he is a top bloke!!!
    Hes a great bloke and good mechanic. Lent me his bike and a Derby barrel to look at He may be at the track on Saturday taking photos in the morning
  2. #4052
    I am hoping this V Tech inlet idea will add an extra 1000 or so rpm on the bottom end to beat those FXR's in the power spread stakes. Blue line, GP125 2-Stroker Red line FXR150. The idea is that at low rpm, the half butterfly closes, the area of the inlet tract is smaller and the rotary valve closes earlier, thereby increasing low end drive, hopefully from 6-7,000 rpm.
  3. #4053
    Unless it's virtually touching the disc I doubt you will see an improvement, but II like your thinking. How abut a YPVS controlled guillotine at the disc face. That would be hard to engineer but give clear results?
  4. #4054
    I have thought about a guillotine at the rotary valve face like you suggest, but found it hard to impliment, so chose this method which also has the benifit of a bit of length to the reduced inlet tract for some ram effect and other benifits like increased crank case volume at low rpm for extra low end torqe.
    My original drawing shows the divider extending to the rotary valve face, the half butterfly was a refinement suggested by Wobbly. I realy hope this works, then we could have powerfull and easy to ride 2-strokers.
  5. #4055
    if only there was some way of providing a constantly variable intake timing solution to the inlet of a 2 stroke that suited the engines demand. Perhaps based on a wind instrument technology. I think I'll call it Torque Induction.
    To the patent office!
  6. #4056
    Torque induction , sounds like some clever way to induce labour. Now there is a variable intake tract to base future innovations on.
  7. #4057
    if only there was some way of providing a constantly variable intake timing solution to the inlet of a 2 stroke that suited the engines demand. Perhaps based on a wind instrument technology. I think I'll call it Torque Induction. To the patent office!
  8. #4058
    14th June 2009 - 15:13
    suzuki
    europe
    Another method that has been used before is two intake ports and two carbs with staggered throttle opening. This also allows you to run different intake lengths and even carb bores. See Cesare Bossaglia book from early 70's for some photos of kart engines running this set up.
    My father in late 70's converted a 125 air cooled disc valve engine to this setup that ran very sweet and had a lot of race wins.
  9. #4059
    Giant list of books about the two-stroke cycle engine/ Two-Stroke motorcycles:
    While searching for Cesare Bossaglia book that Sonic_V mentioned, I found this great books list on http://www.2strokeworld.com/forum/in...p?topic=2022.0
    Tuning the Two-Stroke Motorcycle
    by Motorcyclist Mini-Manual
    Publisher: Peterson Publishing Co.
    Pub. Date: 1973
    ISBN: NA
    64pp
    Souping Two-stroke Engines for More Power and Speed (Pamphlet)
    Publisher: Floyd Clymer Publications
    Pub Date:1954
    ASIN: B00124WLVE
    46 pages
    Two-Stroke Ports for Power
    by Roy Bacon
    Publisher: Lodgemark Press Limited
    Pub. Date: 1968
    ISBN: NA
    52 pp
    Two-Stroke Carburetion and Ignition
    by RoyBacon
    Pub. Date: 1970
    SBN: 850770084
    51 pp
    Two-Stroke Exhaust Systems
    by RoyBacon
    Pub. Date: 1967
    ISBN: NA
    47 pp
    Rotary Valve Two-Stroke Engines
    by Alan T. Burgess
    Pub. Date: 1971
    SBN: 850770211
    104 pp
    Two-Stroke Motorcycles and How to Get the Best From Them
    by staff of Motor Cycle
    Pub. Date: 1967
    ISBN: NA
    138 pp
    Improving Two-Stroke Engine Performance
    by J. W. Vierdag
    Pub. Date: 1967
    ISBN: NA
    126pp
    Tuning Your Two-Stroke Engine, Motorcycles, Go-Karts, Outboards, Lawnmowers, Etc.
    by K.G. Draper
    Publisher: Coles Publishing Company
    Pub. Date: 1977
    ISBN: NA
    125 pp
    Two-Stroke High Performance Engine Design & Tuning
    by Cesare Bossaglia
    Pub. Date: 1972
    ISBN: 0850770289
    227 pp
    The High-Speed Two-Stroke Petrol Engine
    by Philip H Smith
    Publisher: Whitefriars Press Ltd.
    Pub. Date: 1968
    ISBN: NA
    423 pp
    The Two-Stroke Engine Design and Tuning
    by KG Draper
    Publisher: G.T. Foulis & Co. Ltd.
    Pub. Date: 1973 5th ed.
    ISBN: 0854291571
    128 pp
    Two-Stroke Tuning
    by Roy Bacon
    Publisher: Transport Bookman Publications
    Pub. Date: 1981
    ISBN: 0851840396
    127 pp
    Motorcycle Tuning Two-Stroke
    by John Robinson
    Publisher: Butterworth-Heinemann
    Pub. Date: 1994
    ISBN: 075061806X
    169 pp
    Two-Stroke Performance Tuning
    by A. Graham Bell
    Publisher: Haynes Publishing
    Pub. Date: 2nd Ed.
    ISBN: 9781859603193
    271 pp
    The High-Performance Two-Stroke Engine
    by Dr. John C. Dixon
    Pub. Date: 2005
    ISBN: 1844250458
    290 pp
    Two-Stoke Power Units, Their Design and Application
    by P.E. Irving
    Publisher: Hart Publishing Company
    Pub. Date: 1968
    ISBN: NA
    288 pp
    Two-Stoke Tuners Handbooks
    by Gorden Jennings
    Publisher: H.P. Books
    Pub. Date: 1973
    ISBN: 0912656417
    156 pp
    The Two-Stroke Cycle Engine, Its Development, Operation and Design
    by John B. Heywood and Eran Sher
    Publisher: SAE International
    Pub. Date: 1999
    ISBN: 1560328312
    451 pp
    The Basic Design of Two-Stroke Engines
    by Gorden P. Blair
    Publisher: SAE international
    Pub. Date: 1990
    ISBN: 156910089
    672 pp
    Emissions From Two-Stroke Engines
    by Marco Nuti
    Publisher: SAE internationl
    Pub. Date: 1998
    ISBN: 076800215X
    283 pp
    Scavenging of Two-Stroke Diesel Engines
    by Paul H. Schweitzer
    Publisher: The Macmillan Company
    Pub. Date: 1949
    ISBN: NA
    265 pp
    Design and Simulation of Two-Stoke Cycle Engines
    by Gordon P. Blair
    Pub. Date: 1996
    ISBN: 1560916850
    623 pp
    Two-Stroke Engine Theory and Diagnostics
    by Yamaha Motor Company
    Publisher: Yamaha Motor Company
    Pub. Date: 1998
    ISBN: NA
    28 pp
    Three T’s for the Two-Stroke, -Theory, Trouble-shooting, -Tuning
    by Yamaha International Corportation
    Publisher: Peterson Publishing company
    Pub. Date: 1969
    ISBN: NA
    33 pp
    SAE Technical Paper Collections:
    Two-Stroke Cycle Spark-Ignition Engines PT-26
    Pub. Date: May 1982
    ISBN: 0898831148
    ISBN-13: 978-0898831146
    457pp
    Advances in Two-Stroke Cycle Engine Technology PT-33 by (SAE technical papers)
    Publisher: SAE
    Pub. Date: Jun 1989
    ISBN-10: 0898831202
    ISBN-13: 9780898831207
    485pp
    Advanced Two-Stroke Engines PT-942
    Pub. Date: March1993
    ISBN: 1560913274
    ISBN-13: 978-1560913276
    171pp
    Progress in Two-Stroke Engines and Emissions Control
    Pub date: March 1996
    ISBN-10: 156091761X
    ISBN-13: 978-1560917618
    158 pages
    Two-Stroke Engines: Technology and Emissions
    Pub date: December 1998
    ISBN-10: 0768001269
    ISBN-13: 978-0768001266
    706 pages
  10. #4060
    A splitter could be run from the butterfly shaft back to the disc valve then you would better reduce the opening of the disc valve port. As F5 points out, all the valve is doing at the moment seems to be reducing the area of the port. The disc valve timing wouldn't seem to be altered.
  11. #4061
    Its a work in progress, the splitter was shown in the original drawing. The half butterfly instead of the gate was a refinement suggested by Wobbly.
    Attachment 238826
    Bucket and I will hopefully get to finish the V Tech inlet next week and run it up on the dyno later.
  12. #4062
    10th December 2008 - 07:39
    07 fz6n. 07cbarrrr600
    STRAYA
    Would it be possible to use two disc valves in unison ?
    One being fixed to the shaft, the other floating next to the fixed disc. With a mechanism to "advance or retard" it at varying rpm..
    With the theory that the floating disc could rotate to reduce the port area at low rpm etc..
    Or even make the port in the case variable ? With say a similar set up to a carb ? That opens as the revs increase..
  13. #4063
    give me a break Kelly,this thing needs to go to the track to see what it can do and if it will last a days racing.
    Thanks to Kel and Gigglebutton for giving it a good run and their feedback.
    I know it was only practice, but the engine proved itself and lasted all day, and it drove pretty much like you would expect it too, phat, but the bike needs some good tires and suspension setup to make it a real weapon.
    Before we race and risk breaking it, there are a few things I wan't to do, like dyno the V Tech inlet and try water injection to go with it, then there is the electric power jet carb. And most importantly, get the suspension sorted and a spare set of wheels with wets.
  14. #4064
    Rg50 Fxr's150
    Test ride
    Sorry for dropping your bike Rob I have to say FUCK Yeah!!!. It is amazing. Sooo phat and it seams to have no end to the amount of revs you can pull. 1 gear up and 1 gear down round Mt Welly. You can short shift in the sweeper and drive out with that massive torque. Clutch it and it goes into "Warp Drive" Get the handling sussed and it could be a GP winner. Cheers mate, Dazz
  15. #4065
    GP125, from the dyno to the track!
    TZ is looking a bit pale after Giggles had sent the bike down the track so I get the "just take it easy we're not sure about the tyres" talk before I’m let loose. I ease around the left hander onto the short back straight and effortlessly blow by 3 bikes, get into the sweeper short shift and then open the throttle and let it wind up, holly crap what a rocket! The dyno runs show the GP producing 85% more power than my FXR well it feels more like 200%!
    The objective was to ride the GP like the FXR i.e. only using 2 gears, the bike certainly felt capable but with lack of familiarity I was hesitant to try and set any kind of pace. I come back into the pits and after adjusting tyre pressures jump back on the GP with the conviction of doing a couple of reasonably quick laps but when I up the pace it starts pushing the front end. Not to be deterred I go harder then its pushing the front and sliding the rear. The rear end breaking loose is fantastic but the front end is starting to worry me and that little voice inside my head is saying "hey it’s not your bike don’t break it", shame the voice wasn’t speaking to Giggles . The bike has also developed a delay in coming back on the throttle so I reluctantly take it back to the pits.
    So the verdict - Firstly I didn’t do the bike justice but it sure was fun. The power is wide and smooth and when its moving its really moving. With a decent set of slicks, a good rider and some dialling in the GP has the potential to win many races. I certainly wouldn’t want it behind me on the final run to the line.
    TZ, Vee rubber slicks?
