Page 458 of 458 FirstFirst ... 358408448456457458
Results 6,856 to 6,865 of 6865
  1. #6856
    At home to Mr Bang
    Dude I am super popular. Got invited to a Tupperware party the other day. Good stuff I tell yah. I am sorry about causing you pain with the oil spill. My wallet is suffering as well.
    Reading between the lines rather than the results
    Was there an engine incontinence incident.
    From what i understand it is common oversea's as far back as the mid 90's for un house trained 4 stokes to be made to Wear "Diapers" (IE belly catch tanks)
    Shame yo hear though, again as well Rich.
    is the carb and new piston ok?
    Oh yeah how many engines does Rich have to disembowel before he is classified as a serial killer, or is in Euthanasia
  2. #6857
    Do you not venture far out of this thread?? Try looking at his Autopsy thread.
  3. #6858
    One thing I completely disagree with in the piston seizure write up is that air leaks cause a lean condition.
    This is utter bollocks, any engine with a case leak will run richer, the bigger the leak the richer it will run.
    Caused by the fact that the case "pump" no longer works and the fuel air mixture isnt being transferred thru the ducts.
    If the engine is then leaned up to "fix" the incorrect mixture - then it seizes.
    wobbly, are there any benifits in being able to control air into the crankcase, with this richening phenomenon.
  4. #6859
    17th December 2015 - 06:22
    Yamaha
    California
    Wrist pin offset
    Please help me find detailed information about the effects of wristpin offset
  5. #6860
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    all these year later and i still see this floating around lol
    i'm over buckets
  6. #6861
    13th April 2009 - 22:30
    Maico Bimota 250
    T250
    Busy rebuilding a T250. I'm battling for tuning info on these. I'm making it std to start with but wanted to know what are the next steps. An upgrade from the 2 transfer ports would be good. Any later models with more ports that are interchangeable would be good.
    Maybe a slot in the cylinder to create a boost port could be an option.
    Lastly any recommendations on which other older 2 stroke forums are worth looking at. I've looked at dozens but not very informative. Lots of individuals have posting of mods.
    PS My motors were 1st 3rd and 4th in the BOB and I can't remember if I worked on 2nd or not. What pity we had no North Islanders there. Scaredy cats !!!
    Cheers Wallace
    http://www.marshland.co.nz
  7. #6862
    19th October 2014 - 17:49
    San Francisco
    Wallace, I think X6/T20/T250s often get filled with Yamaha rods/bearings/pistons, so you might look there. I think with the TD3 they went to square b/s from the 56/50 of the earlier bikes.
    cheers,
    Michael
  8. #6863
    cheers,
    Michael
    Yes, TD3 is 54X54 - I've already told him that Mike Sinclair won a NZ250 title with TD3 barrels on his T20....
    The one he's working on should be left pretty stock IMO. Owner is a social racer....
  9. #6864
    1st December 2020 - 17:53
    KTM 690
    Florida
    engine work
    I think Uniflow was suggesting that at very high rpm - the engine was running harmonically.. all in 'continuous flow'..
  10. #6865
    9th July 2020 - 04:00
    Suzuki GP100
    Scotland
    Bit of a bump for this old thread but!
    I'm building a GP100 to take to Bonneville, only going for production records so no big changes. Basically the bike has to appear standard and have the standard venturi size. Other than that you can get away with changing internal parts. Currently I've got a sort of expansion chamber welded into the standard exhaust, barrel ported, rotary valve cut to gp125 spec, standard carb bellmouthed instead of the standard shape. Got a thin spacer under the barrel, barrel skimmed and o ringed.
    Went from 9.6rwhp to around 13.6, have done a couple mods since but would love to get more out of it
    https://iili.io/7XD8js.md.jpg
    https://iili.io/7XDvun.md.jpg
ID:	350233   Click image for larger version.
