Page 62 of 458 FirstFirst ... 1252606162636472112162 ... LastLast
Results 916 to 930 of 6865
  1. #916
    My MB sidecar engine had a Keihin 28mm carb, beautiful little carb. Every other engine has always had the old 32mm round slide Mikuni and even the same main jet.
  2. #917
    I am Feeling very depressed today. I have finally got a handle on Jennings Time-Area/Angle-Area chart and how to use it and its not looking good.
    Gordon Jennings:- http://www.vintagesleds.com/library/...20Handbook.pdf down load it from here.
    To use this chart you need to know the port open duration and the mean area of the port, which is roughly ¾ of the total port area.
    Finding the “SPECIFIC ANGLE AREA” for the “DISC-ROTARY INTAKE” on my Suzuki GP125.
    First, the inlet port is slightly bigger than the 24mm carb, port area = 5cm2.
    Second divide 5cm2 by 125cc and get 0.04.
    The inlet timing is, inlet opens 145 BTDC, closes 85 ATDC so the port open duration = 230 degrees.
    Now 0.04 times 230 equals a “SPECIFIC ANGLE AREA” of 9.2.
    A “SPECIFIC ANGLE AREA” of 9.2 just puts me into the 8,500 rpm region of the chart.
    The only way to move to the 10,000rpm region is to increase the inlet timing and lose low-end torque or increase the size of the port but this is limited by the carb/port size relationship.
    The 24mm carb limit has got my hands tied. A 28 would be good and a 32 just right.
    This time-area.angle-area chart is a real easy way to figure if youve got enough port size and/or duration for the rpm you plan on using.
  3. #918
    29th September 2003 - 20:48
    2008 DRZ400E & 1983 CB152T
    Alexandra
    The only way to move to the 10,000rpm region is to increase the timing and lose low-end torque or increase the size of the port but this is limited by the carb/port size.
    Well I think the only answer is to buy an fxr...
  4. #919
    8th August 2007 - 19:12
    Best Bitza Bucket 2008 BoB
    Norf Welly, it's MASSIF!
    Wash your mouth out!
    Not enough cylinders
  5. #920
    I
    Just to play devils advocate...is it possible to simply fit a bigger carb and test on the dyno (just for comparison)
    I guess that is just academic, but it would be interesting aye!
    10,000 RPM really is where you want to aim (aim my opinion), given the fact that you have an unsuitable gear box, but (as you are more aware than anyone that dammned 24mm carb really limits you!
    My experience tells me that such an engine is possible (previous graphs), but, like I said, 28MM carbs (and up) are required!
    PERHAPS (just a suggestion) you could reconsider your current cylinder, and simply make the engine (with different exhaust port timing) for low down power (with an ignition and pipe design) that simply allows for alot of "overrev", giving you not only an easier bike to ride, but also an engine that will have (similar) power characteristics to an FXR150.... (maybe)
  6. #921
    Maybe start looking for a gp100 barrel
  7. #922
    Alexandra
    Quote Originally Posted by Sully60 View Post
    We don't want everyone finding out how awesome cb's are! Leaves no spare parts for us
  8. #923
    That is a bloody good idea!
    Sorry Teezee, but that may well be worth consideration!
  9. #924
    Links to Tech Stuff.
    An assortment of Gennings Articles:- http://www.edj.net/2stroke/jennings
    Graham Bell:- http://www.kreidler.nl/artikelen/per...raham-bell.pdf
    Yamaha SAE Paper on Porting:- http://www.2stroke-tuning.nl/media/pdfjes/porting.pdf
    Rate of Fuel Burn:- http://www.factorypro.com/tech_tunin..._vs_power.html
    Reading Plugs:- http://www.dragstuff.com/techarticle...ark-plugs.html
    Engine formulas:- http://members.bellatlantic.net/~vze...es/engine1.htm
    A Handy Coverter:- http://www.mr2ownersclub.com/converter.htm
    Detonation:- http://www.factorypipe.com/t_deto.php
    Dale Alexander. The Art Of Squishing Things Until They Make Power:-
    http://www.aircooled-rd.com/default....ge=squish1.htm
    http://www.aircooled-rd.com/default....ge=squish2.htm
    http://www.aircooled-rd.com/default....ge=squish3.htm
    A preview of Kevin Camerons book “Sportbike Performance Handbook”:-
    http://books.google.co.nz/books?id=L...esult#PPA81,M1
    TUNING VESPA'S THE NORRIE KERR WAY.....
    http://www.scooterhelp.com/serial/tuning.books.html
    Crankcase delivery ratios and inlet timing for rotary disk motors:-
    http://www.edj.net/2stroke/jennings/delivery_ratio.pdf
    The effects of crankcase volume on the delivery ratio:-
    http://www.edj.net/2stroke/jennings/...ase_volume.pdf
    Piston pin offset and what it means for extra power:-
    http://www.motorcycleproject.com/mot...ws-offset.html
    4-Stroke stuff but very interesting about porting and combustion.
    http://www.gofastnews.com/board/technical-articles/
    Terminolagy:- http://www.2-stroke-porting.com/terminology.htm
    Modifying a Suzuki open chamber to a squish head:- http://www.ozebook.com/compendium/t5...organ/head.htm
  10. #925
    The problem with that is the whole inlet tract and port have to be reworked to suit the larger carb as the area of the port window needs to be just a whisker bigger than the carb.
    A complete 100cc engine is starting to look like a good idea.
  11. #926
    Yea, while I feel for all your hard work (and Thomas's....) with what you have learned from the 125, to apply it to a 100 would be quite amazing (and you could water cool the head as well)...... In THEORY you should be able to make more peak power than an MB100 (but alas, you get "fingered" by that transmission again), so making the bike rideable (with port timings to to extract that power might be hard work (but certainly possible).
    Don't give up though.....not everything about two stroke tuning can be found in a book written in the 70's......
  12. #927
    I would buy a XL100 first and supercharge it, then your FXR's would be in real trouble.
    Supercharged Honda 50 http://www.elsberg-tuning.dk/the%20bikes.html
    Superchargers.
    The smog pump - cheap and plentiful. Used on automobile engines since late sixties.
    The Aisin AMR300. From Subaru Kei- car - 660cc supercharged citycar.
    The KF Max10- 25. American aftermarket blower.
    The Hansen V12. Made especially for supercharging Kart- engines from 5- 20hp.
    Thanks to TerraRoot for his post on the Blown FXR thread.
  13. #928
    24th September 2006 - 02:00
    I've seen that before. Very impressive -- same motor as in my little Honda C50, which tops out around 65kph. He says he hit 142kph. Stock cam!
  14. #929
    Quote Originally Posted by xwhatsit View Post
    The way to get drive out of a supercharged 4-stroke is to use the stock or milder than stock cam. As you are blowing the air in and don't need all that super cammy stuff.
  15. #930
    Apparently it has been done before...
    As far as I understand (so I'm probably wrong!) one major problem with supercharging (With a positive displacement blower) small bikes is the clearances in a blower stay more or less the same regardless of size so the smaller the blower the greater the pumping loss % or somthing like that anyway...
    I did a bit of research on the Aisin AMR300 and AMR500 as I was looking using one on my VW Beetle. I think a 100 would have a fair ammount of trouble spinning it!
    I think (Just as an idea) if you really did want to play with such a thing the compressor side of a tiny turbo would probably be worth looking long and hard at.
    A. Graham Bell also has a great book on forced induction tuning.
    Edit: Ahh, I see the guy in that article cut his blower down!
    Smart bastard!
