Page 67 of 458 FirstFirst ... 1757656667686977117167 ... LastLast
Results 991 to 1,005 of 6865
  1. #991
    Not a 2-stroke I think but a very clever piece of German kit.
  2. #992
    4th November 2003 - 13:00
    BSA A10
    Hows that for different!!!!! It looks like the underside of the piston sweeps a much larger volume than the piston side does. So the motor looks like it is supercharged like the old DKW racers were.
    And a water cooled piston no less!!!!
    Something different and made in NZ.
    http://www.pivotalengine.com/
    Thats been around for a while I remember seeing it at Ruapuna on display at at Race meeting quite some time ago
    I see it says 02 on one part of the site
  3. #993
    The Two-Stroke Shop
    Stephen Rothwell and Wayne Wright (Wobbly)
    www.twostrokeshop.com
    Email: info@twostrokeshop.com
    THE most advanced high-performance two-stroke motorcycle engine on the market today.
    http://www.twostrokeshop.com/two_str...op_engines.htm
    Toroidal head and flat top piston.
  4. #994
    Did they have it running? I see the power output is not that high. Still clever stuff though.
  5. #995
    The effects of higher compression ratios in a 2-stroke:-
    http://www.vintagesleds.com/library/...ompression.pdf
  6. #996
    "You may be interested to know, that in many cases a non-squish combustion chamber, with its complete utilization of the mixture to offset the power-limiting effects of a necessarily-lower compression ratio, has proven to be best in absolute terms of power and economy."
    Read it all here:- http://toostroke.blogspot.com/2007/12/squish-bands.html
    "Our application here, of course, is strongly biased toward maximum horsepower, and that points toward a squish-band head - which is what you will have in most motorcycles in any case. I will warn you, now, that it may be unwise to follow the old-time tuner's habit of increasing an engine's compression ratio as an opening gambit in the quest for better performance. Indeed, before your work is done you may find it necessary to reduce your engine's compression ratio below the stock specification. You see, in the final analysis it is not so much compression ratio as combustion chamber pressure that determines the limit - and these are not at all the same things."
    It looks like combustion chamber shape can be a trade off between broad power and maximum horsepower.
    As team ESE is running basicaly identical Suzuki GP125 engines except for combustion chamber shape it will be interesting to see how this plays out over the next few dyno runs at Henderson Yamaha.
  7. #997
    A cataloge search engine of all things!!!!!!
    Lots of 2-stroke piston stuff. Probably can find rod-kits and other bucket stuff if you look.
    http://www.who-sells-it.com/r/mahle-...-2-stroke.html
  8. #998
    If there is any rule for the inexperienced to keep in mind. it is that everything a reasonable intelligent person should intuitively believe to be right will probably be totally wrong.
    http://www.bmw-m.net/techdata/cylinder.htm
    The inlet port needs only a slight convergence of 1.5 degrees included angle, which doesn't sound like much. But a 12 inch section of aluminum pipe taper-bored for a 1.5 inch inlet and a 1.498 inch outlet flows better than a parallel-wall pipe, and a lot better than air going from the cones' small end to it's beg end. Sound waves love a divergent duct, air flow does not.
  9. #999
    29th September 2003 - 20:48
    2008 DRZ400E & 1983 CB152T
    Alexandra
    The Two-Stroke Shop
    In 01 RS125's converted to a head like that, supposedly it gives a better power delivery for running off unleaded. I think around 03-04 they went to flat top pistons for the a-kit ($10k+ engines) for again better power delivery for the unleaded fueled bikes. Afaik all the world gp bikes run flat top pistons and i would guess a combustion chamber of some shape like that. I was told it helps push the fuel mixture back down towards the piston before the spark plug fires.
    For the leaded fuel everyone still runs dome top pistons and a standard shaped combustion chamber. Its a bit hard to know what to do though. Since world gp converted to unleaded in 97 (I think?) all the development has gone down that avenue. There are only a couple of countries that still allow leaded fuel so we just stick to the tried and true and that seems to do the trick
  10. #1000
    2nd January 2009 - 20:18
    Suzuki 125
    TZ as your looking at combustion chambers and transfer patterns I found this for you. It talks about the pistons head/squish area on the left being from the old school of 50% bore dia and the one from a head made with an eye on the MSV Mean Squish Velocity produced.
    From:- http://www.saltmine.org.uk/shoeman/heads.htm
    "Piston on the left came from a motor using a conventional head design. It has suffered some detonation as shown by the small pieces of carbon that have been knocked off the centre of the dome. Note how the baked on stuff extends all the way to the edge of the dome in parts. The piston on the right was used with a well developed squish design head. The area of maximum heat has been confined to the centre of the dome. No carbon and oil residue approaches the sides of the dome at all, indicating no mixture is being trapped there and burning on. You can also see evidence of the flow pattern in the cylinder by reading the shading on the dome. The cooling effect of the flow from the secondary transfer ports is very easy to see in the two very light coloured small areas at the top of the piston. This is what you like to see when you remove the heads from your motor."
    More from the auther can be seen here:- http://www.saltmine.org.uk/shoeman/
  11. #1001
    Suzuki 125
  12. #1002
    This may be of interest "How to Choose a Power Band" by Eric Gorr.
    http://www.whidbeyparts.com/info/How...apowerband.pdf
  13. #1003
  14. #1004
    Bugatti
    The engine is about 12.66cc, one cylinder, 2 overhead cams and a supercharger.
    http://www.bugattirevue.com/revue29/t72.htm
    The smallest Bugatti, measures only 12.66 cc. recently photographed in France, the one prototype built in 1944. Dimensions are 24 x 28, plus supercharger and gear driven overhead valve gear. It was capable of 10,000 RPM. The detail pictures below speak for themselves, really a very fine piece of engineering!
  15. #1005
    A page about moving heat:- http://www.koolance.com/technical/cooling101/002.html
    After reading this I can see why TZ is using copper in his cooling system.
