Maybe we will be on mobility scooters before Kickaha gets it bucket going again
Artistic license. But seriously the tracks for the most part are not generally HP tracks. (there are a couple of notable exclusions of course.)
I think the main reason is because the Fxr150's are now so ubiquitous that as 75 percent of the field is mounted on them and thus the number would then suggest that generally most of the fastest rider will probably be on them as well.
Also the FXR are a modern design as well they are a generation ahead of the 2 stroke engines freely available.
Its just that no manufacturer makes a serious 2 stroke liquid cooled bike case reed or disk valve power valve anymore or ever really, also no half way serious 125cc ac 2 strokes since the early 80's.
The people that have the skill to create or pay to have a genuine contender 2 stroke are pushing 40 or older with kids and responsibilities.
and are a little (lot) heavier.
I for one are going to try and stop the rot even if it means having to have someone else take up the ridding duties.
Page 390 Technical Posts from the last 10 pages. There are other collections on each decade page back to page 80.
Husaberg has posted many interesting articles, the best way to find these is to use the Thread-Tools then View-Thread-Images and then sort them from the beginning and 70 a page, there are about 3,000 images on this thread.
Some engine development tips
A very informative post on specific heat ….. its worth a read.
Simulation for Husaburg to see if the simulator will show him any performance advantage with using a positive offset.
Attachment 253491
Attachment 253467
+5mm offset, not much in it. will try 12 forward next.
Attachment 253475
+12mm offset
Its negative offset or backwards compaired to crank rotation to reduce noise and positive for performance. The simulator doesn't see much in it. But it did affect the combustion chamber volume for correct compression ratio.
My experiance with wrist pin/cylinder offset as an engine re-building industry insider back in the day was that offset was in the negative direction, and about 2mm or so and was the manufacturers attempt to quietin piston slap as the crank passes through TDC. Get off set pistons the wrong way around in a reco engine and the engine became very noisy.
A bit of time on the net and you can find out all sorts of things.
Attachment 253468
More than anyone ever wanted to know about offset
http://homepages.cae.wisc.edu/~hessel/faqs/kiva4faqs/zpistnCalculationWAndWOWristpinOffset.html
Taken from
http://www.network54.com/Forum/74182/thread/1286357572/1286438278/Offset+vs.symmetrical+piston+pin+-+any+real+difference-
Right, there was a noticeable difference. Some NASCAR racers were disqualified when.....
October 6 2010, 10:12 AM
it was found upon teardown that they had reversed the pistons. Here's what the racers discovered. The factory installed offset was against the direction of rotation which quieted the piston slap noise. But performance suffered because the angle on the rod is increased even more than on a piston with an on center pin. More of the combustion pressure is wasted trying to get over center and pushing the rod "sideways" instead of down. So turning the piston 180 degrees puts the rod and pin at the same angle of offset, but in the direction of rotation. This gives the rod a more downward or straight orientation so that the combustion pressure is not wasted trying to get over center, but is used to push downward.
This is the the same as the "long rod" principle. The geometry is reconfigured in a different manner than modifying the offset, but the end result is the same; the rod is straighter in the bore at any given degree of rotation.
There are a couple more ways of doing the same thing. One is offset overboring in the direction of rotation. The other is casting the crank centerline in the block so that it does NOT intersect the cylinder bore centerlines. Example: the FH V8 cranks were .265" offcenter in the direction of rotation. An FH upside down on a stand really looks strange because the offset is very noticeable. And when it is rightside up and you turn the the crank you notice that as you turn the crank the piston comes up slowly on the upstroke but drops off quickly on the downstroke. This is the same thing that happens when you reverse and offset piston to the direction.
The illustration I always use is the bicycle crank. You remember how hard it was to get you bike going when you tried to push the pedal the closer it was to top dead center. So you would keep pressure on the pedal with one foot while you pushed the bike forward a little with the other foot to get a better or more downward angle on the pedal. Same thing with pin offset in the direction of rotation.
So in other words, the standard placement of the offset piston pin against the direction of rotation hurts performance.
Hollis Franks
Black 63 1/2 XL R Code
Gray 65 289 Falcon Ranchero
I seriously think a fit Nigel on a long track would just make the whole argument mute. Actually I wonder when Bren will do the same duwn sowth.
When Vizard was here some years back he did a seminar for the Engine reconditioning assn in ChCh - fortunately it was an open seminar.
He was frank about inlet resonators - he didn't have the answers yet. the formulas he gave were guides at best and worked on large 4 strokes. Remember, as he said - 70% of all race engines in the world are Chevy based V8's....that's where he earns his $$$.
A maximum of 4 cylinders per plenum - volume for 4 cyl 50 -60% of the volume of all 4. 3 cylinders 65 - 80% of the volume of all 3.
Two cylinders - about equal to the volume of both.
RPM range - lower rpm = bigger plenum volume. Higher rpm = smaller volume.
Hi Husaberg
Attachment 253523
here is a simulation with plus 12 and minus 12mm offset at the pin, you may get the same results by moving the cylinder.
Sorry TZ that was only part of my original attempt post...
Volume within limits is not critical as he says the length of the inlet tract into the resonator can be varied on the dyno to change the system frequency hence torque peak rpm.
He says don't exceed 180 ft/min on the intake velocity into the plenum - doubt you'd exceed that with a 24mm carb on a 125.
Given the shape of your existing plenum TZ, flow lines could be a problem with making it smaller.
There's got to be more up to date info somewhere on the web - even if it's 4 stroke based the principles are the same
More for Husaberg
Attachment 253546 Attachment 253545
Differences in combustion chamber volume for the same corrected compression ratio.
Attachment 253544 Attachment 253547
Plus 12mm Minus 12mm STA's
EngMod2T is very usefull and only $400 USD to buy, everyone should have a copy ....
Anyone got anything that'll convert old Auto Sketch SKD files into something useful?
