Results 1 to 7 of 7
Thread: Fuel additive for carb cleaning on a two stroke?
    18th April 2006 - 21:44
    VSTROM - 650XT
    Franklin
    Hi All,
    Is it ok to use a fuel additive to clean a carb on a two stroke? (The bike has an automatic fuel/two stroke oil mixing system)
    If so, what is the best brand to use.
    Thanks
    6th May 2012 - 10:41
    invisibike
    pulling a sick mono
    gull ethanol, or a 15% mix of biodiesel.
    Wasting your time. Screwdriver & 20min of your time to blow through the jets is the only answer.
    the question is what is the question?
    23rd March 2007 - 10:20
    2013 ZX14R SE
    Redex, if you can still get it... I personally haven't seen it in years but it was good...
    26th April 2008 - 00:01
    KTM 950SM, '78 X7, FZ750, GN250
    Pull the carbs off and clean them, fuel additives ain't gonna do shit.
    20th September 2009 - 14:02
    ...usually unsure
    Quote Originally Posted by Sable View Post
    +1
    While a fuel additive couldn't hurt...a strip down and clean will ENSURE the carb gets properly cleaned out ...and you can set the floats etc while your at it
    Last edited by willytheekid; 25th February 2013 at 08:44. Reason: ...im hung over!
    When Life thows me a curve
    ...I lean into it!
    17th February 2005 - 11:36
    Bikes!
    Quote Originally Posted by willytheekid View Post
    While a fule additive couldn't hurt.
    Less gas, same amount of air, lean mixture, hole in piston.
