Results 1 to 3 of 3
Thread: Crankshaft repairs? And parts wanted (fixing my 2003 YamahaR6 racebike)
    30th August 2006 - 17:59
    zx14
    Wgtn
    Heya.
    the engine developed a nasty rasping pinging sound at a recent track day.
    Pulling the engine apart (ok I removed the fairing, which we can agree is the hard part - then watched a friend finish the disassembly) revealing that the bottom end of one of the conrods has sustained damage and also the crank shaft has a bit of scarring as well.
    My mate thinks the crank might be able to be repairable. Any ideas on who can take a look at it and maybe machine it in the Wellington region?
    also I'll need piston, rings, conrod, shells, and head gasket if anybody has parts for a yamaha R6 2003
    Cheers
    Ben
    11th June 2011 - 16:30
    Honda vfr 750 fn 1992 x2 90red
    palmerston north
    Thumbs up
    Quote Originally Posted by bounce View Post
    Heya.
    Cheers
    Ben
    Got qouted 500.00 for vt 250 cranshaft thought was okay price guy talked being 100 % after
    Cold welded built up the con rod bearing if the crank bearing are okay might just be okay with new bearing shells unless it worn beyond the service limits .. if just machine to take out scuffs it be less id though. or you chould have machine slighty smaller then u whould need over sized bearing shells on that side
    23rd April 2004 - 19:16
    2010 DC Skate Shoes
    Roxby Downs, SA
    Buy a new motor. Search on ebay.com - known as R6S over there. Will likely be cheaper to source a complete low mileage motor out of the US than it would be to buy a replacement crank and make it all work. I had to replace a crank on my GSXR1000K4 and that was $1500 with free labour.
    KiwiBitcher
    where opinion holds more weight than fact.
    It's better to not pass and know that you could have than to pass and find out that you can't. Wait for the straight.
