ok so im drilling out my 10mm threads on my POS xl250 and fitting 12mm head bolts
what is the safest way to make the head gasket holes bigger to fit the bigger bolts??
the head gasket is made of 3 layers of some kind of steel with a teflon?? coating,
i have had a play with the old gasket and tried using a die grinder to make the hole bigger but it just makes a mess of the hole
also i will have to remove the locating pins between the head and barrel to fit the bigger bolts will this be a problem as they wont be going back on??
there must be a way with out damaging the gasket, other wise can i make my own gasket out of something???
