Results 16 to 30 of 38
Thread: Water cooling system
  1. #16
    28th March 2013 - 17:54
    Hyosung GT250R
    New Zealand
    Not being timed right, (even mechanics get that wrong from time to time), or a camchain tensioner not being adjusted, (or unlocked after assembly) properly are the obvious ones.
    So the thermostat is not the issue?
    it was awfully hot.
  2. #17
    15th February 2005 - 15:34
    Katanasaurus Rex
    The Gates of Delirium
    Did you check the inlet manifold rubbers when you had the carbs out?
    I've seen split manifold rubbers on Hyosungs which will cause that cylinder to run lean and therefore hot.
  3. #18
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    Quote Originally Posted by Confrontation View Post
    it was awfully hot.
    Could be an issue as well.
    That's a better option than mine!
    Could that really let it run a red hot header at only 1500rpm though?
  4. #19
    17th July 2005 - 22:28
    Dougcati, Geoff and Suzi
    Banjo town
    What kind of bike? The Hyo 250 isn't water cooled.
    Katman and Drew are on to it.
    I highly doubt the ign timing is out, cdi unit would fail, not change timing (you'd hope) and cam timing would make it run like a POS. It'd have to me insanely lean to get a red hot header too.
    Bling your bike out!
    PM me
  5. #20
    Exxon Valdez
    wellington
    Well there ya go. I was even picturing the motor with cooling fins in my head.
    Good thinking that man!
  6. #21
    Hyosung GT250R
    New Zealand
    They are in good condition
  7. #22
    Hyosung GT250R
    New Zealand
    Hyosung GT650R (Carburetor)
  8. #23
    Exxon Valdez
    wellington
    Sweet. Advice still stands.
  9. #24
    27th February 2005 - 08:47
    a red heap
    towel wronger
    PM drunkenmistake, hes an expert on water cooling.
  10. #25
    1st May 2011 - 12:35
    XT660R / TTR250 / 2 old Montesa's
    Blenheim.. now ChCh
    If I leave my XTR idleing for 15mins it will turn the
    right header pipe red... As thats the pipe the AIS
    is on "AIS = Air Injection System" some clean air
    bullshit to burn any fuel that enters the pipe..
    Pete
    90% of all Harleys built are still on the road... The other 10% made it back home...
    Ducati... Makeing riders into mechaincs since 1964...
  11. #26
    the exhaust gases from an internal combustion engine are very very hot.Google it.Then google what temperature it takes to get steel red hot.You will find that a poorly tuned engine can have exhust gas tempertaure of 1600 deg F .Only 975 deg F is red hot steel visible in daylight.
  12. #27
    7th May 2010 - 19:43
    2004 SV1K
    Dunedin
    Has anyone suggested checking the plugs?....
  13. #28
    Hyosung GT250R
    New Zealand
    Quote Originally Posted by DrunkenMistake View Post
    What do I need to check on the plugs??
  14. #29
    2004 SV1K
    Dunedin
    Would start with that, my old Hyo 650 done something similar, the front pipe did not glow red however but it was getting silly hot,
    Front plug was rooted, I dumped the coolant and changed the plugs as part of a service and it seemed to fix it up,
    A new Thermostat wouldn't hurt but I would start with the easy stuff before spending money where it's not needed to be spent.
    A mate also had a similiar problem with his kwak, he had less than 1M ohm on the plug that was related to the cylinder that was glowing the front pipe.
  15. #30
    Exxon Valdez
    wellington
    This, sounds suspect to me. But it aint like I do this shit for a living, so I might have just never heard of it.
