Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Water cooling system
  1. #31
    7th May 2010 - 19:43
    2004 SV1K
    Dunedin
    This, sounds suspect to me. But it aint like I do this shit for a living, so I might have just never heard of it.
    Just saying what happened,
    May not have been the actual cause but it seemed to do the trick.
  2. #32
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    Quote Originally Posted by DrunkenMistake View Post
    Plug heat certainly changes temperatures on a two stroke. I guess it could have a similar effect on a four banger.
    Wouldn't have thought so at idle or just above though.
  3. #33
    17th July 2005 - 22:28
    Dougcati, Geoff and Suzi
    Banjo town
    If the gap was tight enough it'd get hot, but the plug would shit itself long before the header glows red wouldn't it?
    Maybe.
    Bling your bike out!
    PM me
  4. #34
    28th March 2013 - 17:54
    Hyosung GT250R
    New Zealand
    Attachment 283928
    Would start with that, my old Hyo 650 done something similar, the front pipe did not glow red however but it was getting silly hot,
    Front plug was rooted, I dumped the coolant and changed the plugs as part of a service and it seemed to fix it up,
    A new Thermostat wouldn't hurt but I would start with the easy stuff before spending money where it's not needed to be spent.
    A mate also had a similiar problem with his kwak, he had less than 1M ohm on the plug that was related to the cylinder that was glowing the front pipe.
    I just put two brand new plugs on it previous to this happening
  5. #35
    3rd January 2008 - 07:31
    2007 Suzuki DL 650
    North Otago
    Quote Originally Posted by Confrontation View Post
    Could still be a faulty NEW plug
  6. #36
    19th November 2007 - 13:39
    1994 Triumph Trophy 1200
    All over NZ
    Quote Originally Posted by caseye View Post
    Argh! do not listen to Akzle. bloody Waikatoians don't know one end of a motobic to annudder.
    And wheres your Hometown????
  7. #37
    25th January 2008 - 17:56
    New Zealand
    Ah SHUDUPPAYERFACE!
    1 bleed'n circlip away form being mobile again, next week now. Trumpy going good mate?
  8. #38
    21st March 2013 - 12:42
    There are other kinds?
    Always recheck your own work as a start. then check the basics. The flangedoodle actuator valve rarely fails.
    I was a mechanic for too long and manufacturers usually build reliable stuff despite the foil hat wearers whinging.
    And never run a motor with no thermostat, poor advice.
    it can even run too hot due to this, there is some research for you.
    Even in the race cars i worked on we ran a thermostat,At the least if it dies and you are stuck cut the centre out to allow some restriction of flow with the outer ring/flange.
