Results 16 to 30 of 33
Thread: Battery buggered me thinks. Unsure if correct battery
  1. #16
    14th July 2006 - 21:39
    2015, Ducati Streetfighter
    Don't those LifeP04's set your bike on fire? ....................
    Just pulling Eds wiener there.
    Given the ease of use of a battery tender they are well worth the initial outlay for anyone who infrequently uses their ride. NOTE apparently you need a fancy pants one if getting one of the new fangled batteries (I may be wrong).
  2. #17
    26th December 2006 - 20:57
    Pure coolness...
    up in the air....
    Not at ALL......................
  3. #18
    6th May 2012 - 10:41
    invisibike
    pulling a sick mono
    inbuilt balance charge controller
  4. #19
    15th July 2008 - 22:03
    Old classic thing
    If you are in Aucland I can test your battery for you. No charge.
    I can also give it a free recondition desulphation charge for you and the retest it to see if it comes back to life for you with one of our CTEKs.
    http://www.fastbikegear.co.nz/index....40f3b027d9933e
    Once we have done this and know the true state of your battery you make your informed choices from there.
    I've done a bit of work on Moto Guzzi electrics for the guys in IMOC club.
    www.FastBikeGear.co.nz
    Top brand Motorcycle accessories: R&G Racing, Titax, CTEK, Ultrabatt lithium Batteries, RockSolid, BikeVis, NGR, Oberon, Stopit, TUTORO, Posi-Lock, etc.
    Mobile: 0275 985 266 Office, 09 834 6655
  5. #20
    25th April 2009 - 17:38
    RC36, RC31, KR-E, CR125
    Manawatu
    Not sure if they do fancy pants tenders for LFP. They don't like to be tended much, so a fancy pants one would actually just turn off for like 4 weeks then turn on for an hour or two to top it off.
  6. #21
    Said it before on KB. Fastbikegear offers very good service - online from personal experience and looksee above for physical! Well done that man.
  7. #22
    Old classic thing
    Exactly. LFP charges typically charge to 14.6 volts and then turn off to alloy battery to settle back to 13.2-13.4 volts.
    Lithium batteries unlike lead acid batteries do not like sitting at the full charging voltage of 14.6V hence the good ones do turn off once charged and then typically don't recommence charging until voltage has dropped below 13.2v.
    By contrast Lead acid trickle chargers typically hold the charge up closer to their charging voltage of 14.4 Volts constantly.
  8. #23
    Quote Originally Posted by Edbear View Post
    To illustrate the difference between a four and a twin.
    So, despite being the GC that he is, Andrew Stroud is completely irrelevant to this thread then. Glad we cleared that up
  9. #24
    16th September 2004 - 16:48
    PopTart Katoona
    CT, USA
    Fire is such a harsh word.
    I prefer the one "incendiary"
    and to answer you question yes........but it's only a guzzi
  10. #25
    PopTart Katoona
    CT, USA
    Quote Originally Posted by FastBikeGear View Post
    FBG Customer Service to the rescue. Also you better hope there is no charge!
  11. #26
    Old classic thing
    Quote Originally Posted by avgas View Post
    Well we hope we can charge the battery, but there is no $ charge for testing batteries.
    Here's a pic of me after last timeI put my tongue across a motorcycle battery.
  12. #27
    26th July 2005 - 12:12
    Newdlands, Welly...
    Love to take you up on your offer, but in Welly unfort
    ............and to answer you question yes........but it's only a guzzi
    Charming.....
    Actually, when it wouldn't start,.. I said a lot more harsher words to it than that !!
  13. #28
    Old classic thing
    I have developed a special vocabulary for Moto Guzzis....which has on occasions caused me difficulties with some of the guys I ride with. Phrases like "push it over the bank and them climb down and set fire to it" have not always been appreciated.
    But I do lust after a MGS-01 in moments of weakness.
    http://www.totalmotorcycle.com/photo...GS-01CORSA.htm
  14. #29
    Newdlands, Welly...
    I have the sledgehammer ready to take to it sometimes, but then it's beauty (well, to me anyway) overcomes that agitation,... and I calm down trying to figure out just how much Vino the MG designers and engineers drank while designing and building the bike....
  15. #30
    24th June 2004 - 17:27
    So old you won't care
    Kapiti
    Sitting un used or with partial starts and a quick run for a long time is almost certain death for an ordinary battery... Its hardly MG's fault... It would happen to any lead acid battery.
    If you want to keep the bike happy it needs to be started and ridden regularly so that the whole drive train gets up to full operational temperature. Just starting it and reving it a few times is arguably worse than not starting it as it simply adds moisture to the exhausts etc. The oils need to be fully warmed so any water is evapourated out.
    If you cant do that then change all the oils etc, fill the tank to the top and bung in some (or drain it 100%) put it on a stand and remove the battery. Cycle the battery monthly (ie a light discharge using an old headlamp for 45 mins or so and recharge - note DON't flatten the darn thing). Check a few yank sites as in snow country they are very good at this sort of thing.
