Results 1 to 5 of 5
Thread: Fouled sparkplug, poor power and pinging sound
    26th July 2011 - 23:28
    Honda FN75
    Hey guys,
    I have got another issue on my classic scooter (FN 75). I first noticed a pinging sound a week ago. It only happens at idle. I figured it was detonation or pre-ignition so I turned up the idle mixture a bit. The idle speed increased and the sound went away except for occasional pings. When it's happening its a metallic clanging sound that seems to be in line with each rev. I first thought it maybe was a transmission or clutch problem but I'm not so sure now. Reason being, is that my scooter has slowly lost power over the past few days. Top end power seems fine but low end got so bad I tried replacing the spark plug today. So the low end power is back but I wonder if the power loss was caused by whatever is causing the pinging noise. The pinging sound is still there after I replaced the spark so it's not that. I'm not sure what else it could be besides the mixture or spark. I also put the 98 octane gas in so it's not that either.
    Any thoughts?
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    I would be surprised if you can get it to pre ignite at idle, and not burn a hole in the piston before the end of the driveway.
    Anyhoo. Do a compression test I reckon.
    6th May 2012 - 10:41
    invisibike
    pulling a sick mono
    I woulda picked timing.... But not sure how applicable.
    And if only at idle
    timing and vacuum leaks.
    But, yeah, chuck in a new piston and rings just for the fuck of it.
    15th February 2005 - 15:34
    Katanasaurus Rex
    The Gates of Delirium
    Piston slap.
    13th December 2008 - 18:22
    Your mom
    Piston slap.
    Like throwing a sausage down a hall way?
