Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: Help! FXR150 engine won't keep going...
    21st December 2013 - 17:12
    Suzuki FXR150
    Hey Guys,
    I'm new to motorbikes, and have an FXR150. I decided today to do an oil and filter change, which seemed fairly simple - following all instructions in the service manual. After doing this, on the first ride the bike started to splutter a wee bit about 2km down the road and the engine cut. The bike would go for a little when restarted, but got to the point where the engine wouldn't start.
    After this, I had thought maybe I had filled the oil a little too high, as the manual said to check the window while the bike was 'upright' which i had originally assumed was on the stand but later thought I would drain a little so that the window showed oil at the full mark while the bike was vertical.
    Can anyone help me as to what is going wrong... Can't help but think I've mucked up the bike!
    Cheers,
    Michael.
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    come in here and ask http://www.kiwibiker.co.nz/forums/fo...php/91-Buckets
    but sounds like a fuel blockage to me.. a blocked engine breather can do the same as well
    25th April 2009 - 17:38
    RC36, RC31, KR-E, CR125
    Manawatu
    Touch any of the fuel system while doing the oil change?
    How overfill was it when you filled it on sidestand? (should be done when bike is vertial and on a level surface front-back).right filter etc? no oil light?
    Chances are if you've fucked it there will be at least 7 bucketracers willing to take it off your hands... so all is never lost
    Suzuki FXR150
    Hey Guys,
    Cheers,
    Michael.
    Suzuki FXR150
    Na I didn't, the only thing I can think of is that the fuel gauge was quite close to empty - but I immediately went down to get some more fuel in case this was the problem... After filling up the same problem continued... The only other thing I did was tighten the clutch play slightly, but I'm pretty sure I've set that correctly. It still idles fine in neutral but as soon as I put even a little throttle on it starts to choke!
    The oil as it stands currently is at the top mark when the bike is completely vertical. This means that when it is sitting on it's stand, you can't see any oil through the window.
    I got the oil filter through a motorbike dealership and it was the same size, and looked the same. No oil light but I've never seen one on the digital display so I'm not sure where I would see it.
    Before I did the oil change, the bike rode fine, never shut off on me, but having not touched the fuel system I'm a little worried!
    Have you checked all the basics first, such as you have fuel? You haven't bumped the fuel tap to off? Any hoses come loose? Air filter housing all as it should be?
    Unless you have a shit load of smoke coming out the exhaust (you'd probably notice that), or it's dripping out from under your bike (somewhat obvious too), I don't think the extra oil is your problem (but I could be wrong )
    Suzuki FXR150
    I was a little low on fuel, but I immediately went down to get more just in case that was it. After half filling the tank I tried again, bike rode for about a minute but then started doing the same thing. No smoke or anything is coming out of the exhaust, and I checked the fuel tap. It's pretty firm, and is on and the hose appears firmly connected. There is no liquid dripping from the bike, oil or fuel...
    When I put a little throttle on the bike starts to choke (when standing beside it) but idling appears fine... Not sure about air housing but I haven't touched anything other than what I needed to and the bike was riding perfectly fine before I did today's work
    Don't panic man, a lot of the time these things are just something simple you've done without realizing.
    I'd be checking that fuel is getting to the carbs next. If your tank was almost empty if might have sucked a bit of crap from the bottom down and blocked the hose.
    Check on the tube for 'how to' vids.
    Up shot of all this is you'll learn some new tricks
    GPR150
    palmertson north
    Quote Originally Posted by m.tompkinsnz View Post
    take the carb of and remove the flot bowl and blow out , sound like a blocked idle jet
    Suzuki FXR150
    So correct me if I'm wrong but if the muck has been pulled through the hose into the carb, I'll have to clean that out?
    I'm worried that due to how much I've tried it after each attempt at a remedy that I would have pulled it into the carb by now (and clogged the jets or something)!
    Because I suck at finding videos, should I look at disconnecting the fuel line, and flushing it and the tank out? Or is there a better way to check that fuel is getting to the carb?
    Suzuki FXR150
    Cheers, will give that a go for sure, this would still be the case if the bike is still idling fine?
    check the vent in the fuel cap
    GPR150
    palmertson north
    i just bought a fxr 3 months ago , it would just idle but could not get it to rev out , was the main jet and idle jet blocked , the main was worse but still a bit of both
    20th January 2006 - 18:10
    2017 Yamaha MT09 Tracer
    Ashburton
    choke not stuck on?
    Those who risk nothing, Do nothing, Achieve nothing, Become nothing.
    29th May 2010 - 21:08
    ducati 900ss f650
    welle
    That would make sense
