Results 1 to 9 of 9
Thread: Fuel leak at valve. Please help!
    21st January 2014 - 20:07
    Suzuki RG150
    chch
    There is fuel leaking at the valve (see photo) on my suzuki RG150. I tried putting a hose clamp on but its still comes out at a reasonable rate.
    Do i just need to tighten the clamp up heaps, allthough that may split the tube...
    17th December 2011 - 09:01
    ---2000 Triumph SprintT
    Manawatu
    Don't keep tightening. Turn off the fuel supply and disconnect and remove that clip. Pull, wiggle and twist off the hose and check to see where the leak is from. Is it the hose (easy) or the metal tap body (harder)...
    Either the hose is split, or the pipe from the tap is split around the tap housing I would say.
    Suzuki RG150
    chch
    If i disconnect the hose and put my finger over the hole no fuel escapes. the hose does not appear to have any splits although its doesn't fit the valve very tightly. It seems like fuel is just escaping between valve and hose.
    I would say that hose clamp is the cause of the problem. Trying to tighten it has cracked the outlet to the tap.
    There are much better ways to attach the fuel line to the tap ... (cheaper than a bloody hose clamp) most bike shop workshops will give you the proper spring clip. ...
    Suzuki RG150
    chch
    it was leaking before I put the hose clamp on, petrol is only coming out the hole in the valve
    Quote Originally Posted by LiamBirkett View Post
    Too big a diameter hose then ... replace the fuel line and fit the correct spring clips.
    Suzuki RG150
    chch
    will do, thanks for your help
    17th February 2005 - 11:36
    Bikes!
    Sometimes the brass tube in the cast tap starts to leak at the joint. If that is the case, you'll need to wiggle it out, then use something like JB Weld to reseal it in there.
