Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: Hey fix-it guys and mechanics - I need help!
    20th November 2009 - 07:44
    KTM SuperDuke 990R
    I know a lot of you guys on here know your stuff when it comes to fabricating little bits and pieces to customize your bikes or fix things on them, so hoping you might be able to give me some ideas with my little problemo...
    I have an '07 KTM SuperDuke 990r, the model that came with the single seat setup. She's second hand and the guy who had her before me put on a sexy tail tidy and some nice, loud Akra pipes (should be compulsory for a grunty V-twin I reckon!). The problem I have is that the exhausts shake a lot more than they should when riding. I have some brackets to put on them, but the tail tidy has effectively eliminated anywhere to bolt them straight in to.
    So... What I need is to find a circular bracket with a bolt hole in it, so I can put it around the subframe (approx 21mm diameter) and then bolt a metal plate, like a nail board or something down to the bolt hole of the exhaust bracket. This is the simplest way I can see, since I don't have a welder. Been to a few hardware stores though, and nobody seems to have any of these bracket things (I have no idea what they're called). Does anybody know where I could get these or know how to fabricate something that could work? I have attached a little diagram with the parts I need highlighted (A and B).
    I have also had a suggestion that welding some sort of bracket to the subframe could be an option... I just don't know where to start or who to ask about this!
    Any ideas would be greatly appreciated, before my exhausts crack from too much shaking...
    25th April 2009 - 17:38
    RC36, RC31, KR-E, CR125
    Manawatu
    You might be able to find applicable bits in plumbing hardware. But that'd be plan B as it won't look as good as something made specially; perhaps send The Reibz a PM about it.
    15th March 2004 - 13:00
    Austrian and Italian
    Glenfield, Auckland
    KTM SuperDuke 990R
    Quote Originally Posted by Devil View Post
    Figured it would save you having to do it hehe, or me having to harrass you into doing it
    KTM SuperDuke 990R
    Thanks for the help, yeah you're right about it not looking as good but if it's the only option I can find then plumbing hardware it is!
    24th February 2010 - 21:01
    2007 Suzuki SV1000s
    Quote Originally Posted by Kendoll View Post
    Which is kind of appropriate as the diagram you posted looks a bit like a dunny
    9th January 2005 - 22:12
    Street Triple R
    christchurch
    I made a bracket like that for my VFR: some 100 x 2 or so mm alooominum strap, formed it round the exhaust, trimmed it and drilled it. It looks like a piece of jewellery from the HRC race kit.*
    *yeah, not really. But its not too shabby.
    KTM SuperDuke 990R
    Quote Originally Posted by BuzzardNZ View Post
    Haha, I wondered how long before this thread went down the toilet.
    KTM SuperDuke 990R
    Ah-ha! So it is do-able. Thanks! Glad it looks good too
    You could try Affro Engineering or Niggarigg Motors. Both located in Otara.
    Last edited by jasonu; 3rd February 2014 at 15:28. Reason: More racist slurs added
    9th January 2008 - 12:01
    Custom Ag100
    The Tron
    Yeah Bunnings has quite a lot of various sections of ali strap/brackets, may be worth a look.
    15th February 2007 - 12:49
    2002 Kawasaki ZX6R
    North Shore, Auckland
    Would one of these do the trick? You can get them from The Bolt Shop (that's its name) on Archers rd in Glenfield.
    23rd October 2013 - 18:30
    72 Kawasaki A7, 05 Kawasaki W650
    Tauranga
    more_fasterer, that's what I was going to recommend. Replace A and B in your diragram with a P-clip, which you can also get from auto-elec suppliers (they're used to hold wiring looms, among other things).
    28th August 2005 - 19:37
    MT09 Tracer
    New Plymouth Taranaki
    P clip & flexi mount.
    The firmer you mount it the more likely something will crack.
    Suck, Squeeze, Bang, Blow aren’t just the 4 cycles of an engine
    8th January 2013 - 20:18
    2006 Suzuki Hayabusa
    Quote Originally Posted by more_fasterer View Post
    These here would be ideal. If they dont have the right size I could always whip something up.
    Could be expensive though, the bolt shop isn't known for its low prices
