[QUOTE=husaberg;1130706684]The few i have seen that have used the 400 pistons reported shedding of the rings.QUOTE]
Rings were fine, the skirts would crack, but those were the OEM's. RG400 has iron bore.
was it this site http://www.tkrj.co.jp/product/m-piston-kit.html#h
http://www.ebay.com/itm/SUZUKI-RG400-GAMMA-1-0mm-OVERSIZE-PISTON-SETS-RG400-2/141221592096?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222008%26algo%3DSIC.MOTORS%26ao%3D 1%26asc%3D20131003132420%26meid%3D6166461390313735 400%26pid%3D100005%26prg%3D20131003132420%26rk%3D1 %26rkt%3D6%26sd%3D130787011052&rt=nc
1.0mm OS RG400 piston sets, it looks like $109.38 NZD for a set of four.
So it looks like there are plenty of suitable pistons for the different 100cc engines.
Looks like the myth of needing a 107cc oversize allowance and 52mm + pistons because there was nothing else suitable for a 100 in the 50mm bore size is well and truly busted.
Say what on a piston for a bike made nearly 30 years ago for a couple of years as a jap market only bike that you have to buy sets of pistons for in sets of 4. (I guess 2 of which will be different)
But these 4 are All the same size LOL) ship them from Japan.....have 2 sizes only .5mm apart that could work
these are made for a STD road bike reving to about 11000 Yet that no one is able to tell us where you can get pistons with decent rings (Kel says you can but can't prove it)for engines to rev to 14000rpm
.........and you say myth busted, i think maybe your option is plausible (at a push) and only if i are being generous.
The strike pistons are available in any size from 52mm in tiny increments that do no need boring just honing and they are available at pretty much any Kart shop in the country at bloody cheap prices........This equally freely available.............
then again its Far more than Kel has brought forward to prove that ethanol mix fuel doesn't provide a cooling benefit to an aircooled two stroke i would say.......
I am pretty sure this was the company the origional site has moved
and it looks like the range has got far far smaller..........
http://jvt-racing.com/home/?cat=24
