Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 75
Thread: Cordless drill battery repair or replacement?
  1. #31
    25th April 2009 - 17:38
    RC36, RC31, KR-E, CR125
    Manawatu
    Quote Originally Posted by BadSarah View Post
    http://www.trademe.co.nz/building-re...-733105000.htm
    Need a new battery too- a friend of mine says there's no difference in the motors and these will run with the 18v battery giving better torque
    http://www.trademe.co.nz/building-re...-733765888.htm
    I would guess with my drill being a HP146F2B I could use the 18v HP188F2B battery...
    And how do you plan on charging it? or for that matter even fitting it into the drill as it is clearly a different case sizing.
  2. #32
    8th April 2013 - 08:27
    '04 Honda ST1300
    Apparently the only difference (two different pics from two different suppliers) is in the battery cells, but I didn't think about the charging aspect. Damn
  3. #33
    '04 Honda ST1300
    Perhaps I should stick to the original plan of replacing the drill full stop, especially since after reading this thread I'm a little wiser as to battery choice... I obviously use mine too infrequently
  4. #34
    http://www.youtube.com/watch?v=xX_44vDvCr8
    I've got the same tools as this guy and have 3 dead batteries.
    I will try it and post the results.
  5. #35
    9th January 2005 - 22:12
    Street Triple R
    christchurch
  6. #36
    14th June 2007 - 22:39
    Obsolete ones.
    Pigs back.
    Here is a link that is relevant to our interests:
    http://gizmodo.com/scientists-solved...ium=socialflow
    Oh! This thread keeps on giving. Got a new word now "glom". Gonna try & use it in a sentence tomorrow. Cheers.
    Any hoo. Status update.
    One of the postee's (that's a free word to ewes all) mentioned a kitchen fitting co using two drills. Hello, I thought, I spend more time fiddling with me chuck than I do drilling, as it were. If I can get the same drill, new batteries & all etc then I'm going to save a lot of time. A bit each way. Heh.
    So I pop in to see if the Chancellor wanted a bucketful of pies for lunch & shared the idea feeling a bit smug. Pop went the smug bubble & out patoomed the "T'is a bad idea" she said around her Chicken Tikka in puff pastry (a whole chicken), I was crest fallen, "I've just ordered you a new Bosch. It will be here next week & can drill down coz it has an interchangeable thingy which lets you drill in tight spaces". My equipment is generally too big for tight spaces and I end up having to twiddle it with me fingers.
    Roll on next week. And the inevitable "Can you just....." Happy days.
    Manopausal.
  7. #37
    6th May 2012 - 10:41
    invisibike
    pulling a sick mono
    Thought I would start another battery thread as it is raining..
    I have a Makita drill which has 14.4v, 1.3Ah Ni-Cd battery impersonators. They will hold enough charge to put a self tapper about 3mm through toilet paper (double ply, wet, with little dolphins on it). Not ideal. I priced up replacements, $80 each. I can buy the same drhttp://jaycar.co.nz/productView.asp?ID=SB2468&w=ni%2Dcd&form=KEYWORDill new with batteries etc for less than 2 batteries.
    Can the existing batteries be nurtured back to life or am I buying a new drill?
    Seems a bloody shame to bin a good bit of kit for the sake of batteries.
    Opinions & options?
    environmentally, get new batteries.
    OR repack them yourself:
    OR put a cord and some aligator clips on it and keep it in the car/boat.as a corded drill.
    OR, ni-cd os old tech, and heavy, a new drill should be litium ion. - much lighter. and sexy.
  8. #38
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    You can often make one good battery pack from two duff ones.
    They open up, and are essentially a bunch of 1.5V cells soldered together. Identify the dud cells by charging it before pulling it apart, and running the drill for a short burst. The dead ones will have no charge nearly straight away.
  9. #39
    20th January 2008 - 17:29
    1972 Norton Commando
    Auckland NZ's Epicentre
    Get with the consumer program and buy a new one.
    ( says he with a mint Makita with dead battery sitting on shelf but too old skool to throw it away)
  10. #40
    invisibike
    pulling a sick mono
    this.
    except that they are nominally 1.2v cells.
  11. #41
    25th October 2002 - 12:00
    Old Blue, Little blue
    31.29.57.11, 116.22.22.22
    Quote Originally Posted by The Reibz View Post
    Desperately want a Dewalt for the street cred it brings
    You realise they are only a Black and Decker in drag!
  12. #42
    Once Ni-Cad batteries don't hold a charge any more you can often extend their life by freezing them overnight (in a plastic bag, just in case) before thawing in the sun & re-charging. An old wives tale from way back but it works.
  13. #43
    Obsolete ones.
    Pigs back.
    Whats the thoughts on that vid with the guy sparking his battery off a charger? If it works on Ni-Cads that's one thing but if it blows up the charger, shed or me, totally another.
    Re Dewalt. I got my Sabre saw for $60, pre loved. Looks like it's an ex hire tool or has built half of Auckland. Not pretty.
    I've thrashed it since it came home, got a growing collection of shagged blades. I cut up 9 tires today, each into 3. First few I used the saw to cut them up completely but the damage the bead core does to a blade finally made me relent & do the last cuts with a grinder. Tires are ridiculously tough, not the rubber, the wire. I'm suffering from smoke inhalation & some kind of shaking condition in me arms but the Dewalt barely got warm. Bit of a beast.
    Manopausal.
  14. #44
    Whats the thoughts on that vid with the guy sparking his battery off a charger? If it works on Ni-Cads that's one thing but if it blows up the charger, shed or me, totally another. .
    Basically Mark if you got an honest life expectancy from your drill's batteries, there is no amount of black magic that is going to restore them! They are fucked for a good reason. I have tried the defibrillation and the freezing on a couple of lots of batteries in the past to no avail.
  15. #45
    Obsolete ones.
    Pigs back.
    Nice. A good debunking, thank you. I reckon the drill has done it's fair share of work. But black magic? I keep hoping.
    Manopausal.
