Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Yamaha RX/RS125 parts
    27th January 2011 - 11:30
    asdasd
    AKL
    Hey guys
    Does anyone have any Yamaha RX125 or RS125 parts kicking around they don't want anymore?
    Particularly after some engine parts, maybe a cylinder or head, and some front forks (later model ones).
    I figure some bucket racers would have torn them up at some point.
    Cheers
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    What are you looking for?
    asdasd
    AKL
    Firstly, the Yamaha RX125 and the RS125 look incredibly similar. Can anyone confirm the interchangeability of the engine parts?
    I wouldn't mind a head and cylinder for it. It's a friends street legal run around that I want to give a bit of tickle
    The factory RS125 (70s version with a drum up front) forks have cageless bearings in the steering head and the forks are pretty trash too. We're looking at swapping in a slightly newer/larger pair of forks for it. Open to options on this if anyone has any ideas.
    16th November 2005 - 07:48
    I just lost count
    The District of Waipa
    Yep RS and RX are the same engine mate. Not familiar wit the frames at all because and the differences between the two as the one I was playing with was in an odd ball frame.
    I think they switched at some stage between points and CDI ignitions. mine was points and I grafted a AG100 ignition and flywheel on. It made hell of a difference, and reliable.
    Pumba is a wise man.
    I have posted a lot of steering head bearing sizes and fork sizes
    I can't remember where? but on the ese thread I think Rob has a link on pg 1000
    I think I have posted a MX special porting map that was for a MX100/DT100 (ot sure if they are the same stroke or not)I think that was on a page for either drew or white trash
    can you not find an 125 air cooled?
    Oh well if the price was right. I will have a look for a RD Yam reed Valve and reed Rubber unless you have you got any. MY RD stuff is at the old mans but i think there is only plastic ones there though you really need alloy ones as they are ment to be better.
    I have a map of the Porting for the GYT kit somewhere I think. no clymer
    The mx100 had a closer ratio box from memory.yes it did
    DT100A MX100
    1 3.18 2.83
    2 2.00 1.88
    3 1.37 1.37
    4 1.00 1.09
    5 0.80 0.96
    Turns out it is a clymer hot up but i will post it anyway it is old but a start. The MX100 has a 26mm carb vs the DT100 22mm
    The thing with Yamaha's is better parts from the hotter models can be fitted, but more so for the 125cc bikes.
    http://www.kiwibiker.co.nz/forums/at...8&d=1320829362
    http://www.kiwibiker.co.nz/forums/at...7&d=1320829362
    asdasd
    AKL
    Thanks guys!
    Thanks guys!
    If you can find a set of forks for a RD250/350 (one of the early ones pre mag wheels) they had the opposed piston calliper and were the same as the TZ's, much better than any of the later stuff. they changed so they didn't have to pay the paternt fees
    It would look right as well.
    From memory the early wire spoked hubs ones also accept the big floating yam disks in 280 300 320mm if you want to go the 4 pot calliper way for a bit of bling.
    They have likely got the small reed valve as well the RD one would probably bolt on.
    asdasd
    AKL
    Cheers.
    56 x 50 bore stroke on the RX/RS btw
    Cheers.
    So it is more likely to be based on the Dt125/175 series? that opens up some opportunities.
    I have only ever seen pics the ones I remember seemed to be a bit more angular tank more coffin shaped I guess they followed the RD styling.
    asdasd
    AKL
    Well there was a RX125 twin which looked like a RD but I don't know if NZ got these:
    http://www.kaskus.co.id/thread/50a0a...-125-twin-1977
    Yamaha RX 125 Twin 1975 by wimpy kimpy, on Flickr
    Ya going out make me get out a mag now aren't you...
    they were all over MCM mags in the 70's.
    Never seen that twin plenty of RD125's though.
    Google is easier than walking upstairs
    looks like it is based on the 125/175
    http://www.yammy100.com/project-175-t26.html
    http://www.yammy100.com/will-yamaha-...ame-t1685.html
    Well that's clearly an RD engine. Paintwork looks pretty homespun too.
    i've got a DT125 barrel here surplus. was going to graft it onto an MB but Kev went and sold the good spare cases to Dave.....
    If anyone local to you is coming to the BoB it could be picked up at modest cost.
    Must ask him if he has spare clutch basket bits. Cases gone to good use as has a barrel that I'll bring down.
    From memory Dave the other Hondas 4 stroke single clucth bits are pretty interchangeable other than the pressed in center and the pressure plate (they have a alloy one with a larger bearing) they have a wider basket too.
    I think that some of them even had the same number of teeth.......
