Hi all, long story short my 2006 gt250r doesnt really hold its charge, i have a slightly cheap battery in it but when running i would get around 12.6v across the battery terminals (12v not running) then as you rev the engine higher this would DROP to around 12.1/12.2v from memory, im under the impression you want about 14v across the terminals when running
I have replaced the regulator, stator coil and flywheel thinking they were the problem as i initially thought i just wasnt getting enough voltage full stop. im getting around 60 volts ac out of my stator at 5000rpm (service manual says about between 67 and 99VAC at 5000rpm? and if outside these then to replace faulty coil)
i basically have no idea what to do next, only other things i havent replaced are cdi unit, dont think the wiring loom would have anything to do with it?
so frustratedddddjuedkj317d1;
any help appreciated!!!
cheers guys!!!!!!!!!!!!!!!!
Opinions are like arseholes: Everybody has got one, but that doesn't mean you got to air it in public all the time....
