Results 16 to 30 of 33
Thread: Replacing bottom end of FZR 3tj. I need Yamaha advice and parts sources
  1. #16
    Try and avoid Athena sets....and despite the cost the head gsket MUST be OE in my experience. Never struck an aftermarket head gasket for the 400/600 which would last like OE. Clayton at Bob McCleary's for the head gasket.
  2. #17
    4th November 2003 - 13:00
    BSA A10
    Quote Originally Posted by lazaah View Post
    Would you mind explaining why you wouldn't touch it yourself Bob?
    It's because he's a lazy cunt
  3. #18
    5th January 2009 - 19:13
    Yamaha FZR400RR '92
    ChCh
    Anyone know how to select bearings based on journal size rather than part number? Seems Yamaha aren't interested in helping out.
    [Crank part number is 2222232222] Main crank measurements are 30.482 - 30.490mm and piston/big end measurements are 30.482 - 30.486mm
  4. #19
    If you've got a manual which gives bearing shell thicknesses for each colour, simply go to the THINNEST shell. Even if OE is right on the smallest shaft tolerance, all it'll do is give you about 4/10 of a thou extra clearance. Get yourself some green plastigauge - see Appco in Sydenham for that - and aim for somewhere around 1.6 thou clearance on the mains and 1.8 thou clearance on the big ends.
    Those measurements look like a good crank - second hand ? Did it come with shells ? Have you had it linished yet ?
  5. #20
    Yamaha FZR400RR '92
    ChCh
    Excellent, means nearly absolutely nothing to me. I will pass the info on to Kai, it is still sitting in his garage, just waiting on me getting the new bearings/shells.
    The manual does not have shell thickness indicated, just the colours and how to work out what bearings are needed based on the crank and connecting rod numbers. I only have the crank numbers on hand, so I'll have to get Kai to figure that one out. Are you suggesting ignoring the colour coded selection guide and just getting the thinnest shells, or to use the colour guide to select the correct shells and then purchasing the thinnest of those shells?
    The crank is second hand from Rusty, came from an engine which had done a piston (I believe). He gave me a very fair deal. Unfortunately it sounds as those shells/bearings were shagged.
    Getting so much closer to having the bike running again. Only been 6 or 7 years. I have a lot of fieldwork based in the backcountry this summer, will be the perfect excuse to spend lots of time on the bike!
  6. #21
    I'm saying ignore the factory code matches and go for the thinnest shells. As i said, it'll gain you only around 4/10 of a thou extra clearance - which is nothing significant. But it does help...Get the crank linished while it's loose, any engine reconditioner can do that, it's just polishing the journals. Worth doing to a used crank to clean up the surfaces.
    Kai may still have the colour code info on Yamaha shells - the colour steps thick to thin are the same across all yamaha motors. Can't remember which colour is the thinnest sorry. A good yamaha parts man should be able to tell you.
  7. #22
    20th March 2007 - 10:27
    Normally Suzuki
    Agreed, and also get the con rods shot peaned to relieve them.
    shaun@motodynamix.co.nz
    I love my job Call 0223210319--AKA Shaun
  8. #23
    Quote Originally Posted by Moto-Dynamix View Post
    Not a race bike Shaun....poor student on a budget.
  9. #24
    Yamaha FZR400RR '92
    ChCh
    Pretty much!
  10. #25
    If you're in ChCh this weekend - 9/10/11 October, there's a FZR400 powered chopper at the vintage club swap meet for $450. Motor alone is worth that.
    I think it's Hughes Motors from the coast. Over the back middle bay at the swap meet site.
  11. #26
    Yamaha FZR400RR '92
    ChCh
    Ahh bummer, probably would of just snapped that up if I had known
    Finally managed to get hold of Clayton (been trying for three weeks). He said he wouldn't recommend just ordering the thinnest shells and to order by the colour code :/
    His reasoning was that because it is a motorcycle engine (i.e. not a morris minor and spins at > rpm), we can't just go putting oversized bearings in an grind down the crank.
    Should I just insist he orders the thinnest shells and not take no for an answer?
    Thanks in advance
  12. #27
    27th February 2005 - 08:47
    a red heap
    towel wronger
    Yeah I wouldn't listen to Grumph either, I think he's new at this engine building lark.
  13. #28
    5th January 2007 - 14:58
    motocompo
    Buttfuck nowhere
    Would you mind explaining why you wouldn't touch it yourself Bob? I have confidence in my friend who is carrying out the work, he is knowledgeable about mechanics and meticulous in his work.
    Because Grumph makes most every other skilled race mechanic I know look expensive & stupid.
  14. #29
    Thanks in advance
    That's the difference between you and me - Clayton doesn't argue with me....i'll ring him and tell him to pull his head in.
    That motor was being sold by someone using Hughes Motors, greymouth, transport. Might be worth a ring to find out if it sold
    As well as making them look handsome and polite....
  15. #30
    motocompo
    Buttfuck nowhere
    That wasn't for me to say.
