OMFG SO FREAKIN' LOUD AND SOUNDS f*&^ING AWESOME. MY EARS RING WHEN I STOP THE ENGINE. SORRY WHAT? I AM SHOUTING?
Well, loud on the bike anyway. I asked a mate to have a listen why I tried to make as much noise of possible going past (Sorry Island Bay residents) and he reckoned it wasn't going to get me a ticket.
And it has turned my little pops of backfire into something I really notice now. But the next step is to sort the carbs anyway.
Yes, there is a real performance boost from it though, doesn't seem to have destroyed the bottom end of the rev range either. And the bike will have lost several KGs of mass. Popped a mono by accident _while moving_ don't know if that was just my clutch dropping bravado or that extra 2HP I just released though :-) .
Fitting was a snap. it came with instructions, which basically said "cut here" and a hand drawing with 'collector box' annotation with an arrow. My experience went like this:
Saw off old muffler 50mm from the collectorbox. I marked where I should be cutting with a vivid marker. Did it with hacksaw in about 15 minutes, and I managed to cut it straight and clean, which was good. I was suprised to see that the pipe after the collectbox had baffling in it, Honda didn't just put the baffling in the muffler. Tricky..
Put muffler goop on that last 50mm after the collector, slide on muffler, realise not enough goop, take off muffler, more goop, put back on muffler, tighten retaining strap around engine end of pipe.
Fit hanger, which lined up bloody *perfectly* with the the place it was supposed to, the hanger even had a little twist in it at the correct angle to make it easy.
I was really impressed with the appearance of the muffler. It came in a box crammed full of newspaper for shipping, so it was well protected from those with ham fists. It feels rock sold, and is and is very shiny. The outer coating and the carbon fibre trick the eye a little, making seem 'deeper' than it is. The outer carbon mat (The only one I can see..) is in one piece and has been layed straight, along the length of the muffler. The engine end is made out of stainless, including the retaining strap, the bolt looks a little cheaper though. The noisy end is made out of alumilionoinnnmnmn and so is the hanger, both lovingly polished. All the welds look very tidy. The hanger had the nice touch of having a thin coating of rubber on the inside, lessening the chance of scratching the muffler when positioning the hanger. I imagine it might reduce a nasty vibe or two as well.
If you are thinking of something fruity to replace your silly noise reg muffler, take a look at www.rooracing.com and give Alex the friendly pom in Perth a call. Not the cheapest, and once it gets here Customs grab it and make you pay GST. Helpfully, the exchange rate to auzzie dollars is pretty good at the moment. But I don't care how much I spent, I am so happy.
Oh yeah, it sounds absolutely amazing. I was giggling like a school girl for some time. I took 3 or 4 trips through the Seatoun tunnel. Then a repeat effort at the Northland tunnel, shifting up and down, revving it hard or just idling through to enjoy the different sounds.
A 250 shouldn't sound this good. And I'm smiling like I just got a new bike.
I really really want to sort the carbs asap now.. But I'm waiting on that new needle.
