Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 52
Thread: Changing down gears at speed
  1. #16
    25th January 2008 - 17:56
    New Zealand
    So hang on a minute here. You've ridden before, you've bought a Harley and now your experiencing compression lock on a motorcycle that can't go fast enough to pull the skin off a rice pudding.
    Then you come here to ask how to stop this embarrassing thing from happening.
    THIS IS A PISS TAKE YOU LOT.
    OP, do you have a full motorcycle licence?
    is your Harley a 500cc model?
    Do you know that if you simply don't change down before your bikes engine has slowed enough that you won't lock up the rear wheel with compression lock?
  2. #17
    7th December 2007 - 12:09
    Valkyrie 1500 ,HD softail, BMW r1150r
    joined today
    first post....
    piss take
    Opinions are like arseholes: Everybody has got one, but that doesn't mean you got to air it in public all the time....
  3. #18
    19th January 2006 - 19:13
    On any given sunday?
    Works well on a multi cylinder bike ... but the big twins (plenty of engine braking) just like you to just button off the throttle ... untill you need to change down. Much easier on the drive train too ...
    Fuck the drive train mate tis fun sliding into tight corners under.. cough cough.. engine braking,so much so ive resisted the urge to replace the old TLs primitive slipper with one outta a GSXR.
  4. #19
    23rd March 2013 - 12:52
    2004ZX6R
    THE VILLAGE
    Harley riders are oarsum
  5. #20
    10th September 2008 - 21:23
    Yamaha XV250
    te awamutu
    Maybe this was him, at .40.
    https://www.youtube.com/watch?v=QorkezTnmwo
  6. #21
    20th October 2005 - 17:09
    Its a Boat
    'change down gears without locking up the back wheel at speed'
    At speed? give an idea of what you consider 'speed' is? because changing down at any speed can be done without locking the rear wheel. Engine note is a key sound, coupled with experience and an intimate knowledge of your bike.
    If you weight the gear selector with a slight pull on the clutch lever, the bike will change down when the revs allow it, but a large percentage of Harley riders like the 'over do throttle blip' technique when slowing down.
  7. #22
    9th May 2011 - 11:33
    Repsol something or other
    It's so much easier to blip the throttle on a cruiser, you do most of your braking with the rear brake anyway
  8. #23
    Quote Originally Posted by awayatc View Post
    joined today
    first post....
    piss take
    It can't be ... Harley riders are always on the recieving end of a piss take ... aren't they .. ??
    I wonder if he waves .. ??
  9. #24
    ... ive resisted the urge to replace the old TLs primitive slipper with one outta a GSXR.
    It must be the only original bit still on the bike ...
  10. #25
    Thats to help with the wording on the trademe ad....
  11. #26
    I must spread it around ... apparently ... ... later ..
  12. #27
    25th February 2016 - 10:31
    BMW F 650GS
    Manuaku
    Quote Originally Posted by iYRe View Post
    (twist of the wrist 2)
    Every rider should watch it at some point.
    +1 that
    Sent from my iPad using Tapatalk
  13. #28
    4th March 2016 - 14:32
    Honda
    Anywhere you want it
    Just use the brakes to slow down. Then change down when you get within the rev range for the gear you are dropping to.
    Failing that ... buy a small Harley ...
    Not sure about Harley/cruiser's where this is concerned, but on the Sports bike I just slightly load the gear selector then just touch the clutch lever and voila!
  14. #29
    10th August 2016 - 20:32
    The C**t.
    Stockholm
    Quote Originally Posted by Mike.Gayner View Post
    "This unnecessary thing I'm doing is causing me trouble - what can I do to keep doing this unnecessary thing that I don't like doing?"
    Harley riders.
    Well at least he's man enough to ask up for help.
    To argue with a man who has renounced the use and authority of reason, and whose philosophy consists in holding humanity in contempt, is like administering medicine to the dead.
  15. #30
    The C**t.
    Stockholm
    Quote Originally Posted by trufflebutter View Post
    Who the hell uses the clutch to shift.
