Results 31 to 45 of 52
Thread: Changing down gears at speed
  1. #31
    4th March 2016 - 14:32
    Honda
    Anywhere you want it
    Quote Originally Posted by MrMarko View Post
    Who the hell uses the clutch to shift.
    Harley riders it would seem.
  2. #32
    10th August 2016 - 20:32
    The C**t.
    Stockholm
    Quote Originally Posted by trufflebutter View Post
    Uhhh but you do it on your honda
    To argue with a man who has renounced the use and authority of reason, and whose philosophy consists in holding humanity in contempt, is like administering medicine to the dead.
  3. #33
    15th October 2009 - 17:33
    2023 Honda NC750X
    Honda went to all the trouble of putting it on there, might as well use it.
    - The Simpsons
  4. #34
    The C**t.
    Stockholm
    Quote Originally Posted by nerrrd View Post
    Yeah for taking off from stopped. beyond that leave the clutch alone and just use the throttle to let the load off and blip your downshifts... clutched upshifts take forever, aint nobody got time for that.
  5. #35
    Honda
    If you haven't done it on a Honda don't knock it.
  6. #36
    17th July 2003 - 23:37
    CB1300
    Tuakau
    People with some mechanical sensitivity.
    I clutchless upshift when the conditions are right and my timing is on.
    I only do it down enough to keep the skill alive in case I lose the clutch on a ride, it has happened before.
    But having heard many stories about bent selectors and new false neutrals from bad changes, or more likely many bad changes I also choose to use a clutch.
    Pretty much the only benefit out clutchless shifting is a shorter smoother upshift when getting a hustle on but only if your timing is good.
    I don't get why people get their knickers in such a bunch about a skill that is just a preference.
    Sent from Tapatalk. DYAC
  7. #37
    CB1300
    Tuakau
    As one who depends on my bikes and tends to own them for 5+ years at a time the reliability of my bike is way more important than the wank factor of saving a nanosecond on my shifts.
  8. #38
    The C**t.
    Stockholm
    Quote Originally Posted by Big Dog View Post
    Well yeah if you cant time it and are mincing up your box i wouldn't advise it....
    No problem if you can actually ride a motorcycle though.
  9. #39
    11th June 2011 - 16:30
    Honda vfr 750 fn 1992 x2 90red
    palmerston north
    Quote Originally Posted by carlsjunior View Post
    Hello, I am new here and am just looking for a quick tip on how to change down gears without locking up the back wheel at speed. I am used to smaller bikes and have just got a big Harley and can't seem to stop it from happening. Thanks.
    Dont try focus too much on it can get to be obession
    well did in my case when way back.
    Even few years ago and been riding bike with very long break
    since was 15 . yrs old .even know i can stand on back brake
    in emergcy stop. like when some ran out on pedestion stop.
    Just a bad habit of mine
    really for quick answer dont focus on gear changing down.
    and think about using front brake and rear just less and less.
    with torque the engine , braking as well gone to lock any motorcyle back well.
    probley only diffrece becuase harley is alot more wieght.
    and you have more transfer moving forward when braking.
    plus more front fork moment too .
    just leave more time and distance to the corner or intersection its not a competion.
    you dont have to dl to first before a stop . just click down or up from second .
    Id just practice slowing down with front brake and just tiny bit rear if you want get used to that .
    if getting you down and your becoming fearfull do a motorcycle training course
    they dont have to be expesive . i did and really enjoyed it and learned alot.
    never to old to learn. and confidence you get be a asset.
  10. #40
    palmerston north
    after all waffling on came to me
    match engine revs to wheel speed if engine spining faster
    than wheel speed and road speed wheel will be trying go backwards slighty
  11. #41
    palmerston north
    Quote Originally Posted by iYRe View Post
    This will explain it, and many other things beside:
    https://www.youtube.com/watch?v=KVWLIfChUwg
    (twist of the wrist 2)
    Every rider should watch it at some point.
    says no longer avial might just my pc
  12. #42
    CB1300
    Tuakau
    In not saying I can't do it.
    I am saying I only do it when it benefits me and I am secure enough in my penis size / ego to tell others it's not the end of the world if they don't.
    If you ride often enough there will be times when your timing is just not what it should be.
    On the road there is not enough benefit for you to be suggesting you are a better rider because you do it.
    I haven't seen you ride for as least 6 years and even then you were a passenger or in a car more often than riding so I won't cast judgement about who is the better rider.
  13. #43
    14th April 2005 - 12:00
    1990 Yamaha Virago XV1100
    Dunedin
    Quote Originally Posted by actungbaby View Post
    Hardly surprising when the post you're quoting is well over a year old...
    Can I believe the magic of your size... (The Shirelles)
  14. #44
    The C**t.
    Stockholm
    You can drop the attitude for a start?
    In my opinion clutchless shifting well does make you a better rider and has plenty of benefit on the street, as opposed to losing power on a slow clutch shift. in my opinion its alot harder to master a quick clutched shift in regards to getting it right every time than a non clutched shift.
    To each their own.
    Never said you couldn't do it, never claimed to be a god among mortals. So there is no need for the attitude as none was intended from me it's just how i talk....
    My penis size is actually very uncomfortable i think i need a seat with a groove sculpted in it.
  15. #45
    20th June 2011 - 20:27
    Dog Rooter, 1290 SDR
    Marton
    To each their own.
    There is a fair chance his dick is bigger than yours, the guy is fucking huge. I would think he makes his CB1300 look like a 250.
