Results 1 to 6 of 6
Thread: HELP engine noise
    31st December 2017 - 12:34
    suzuki bandit 1990
    Dunedin
    HELP engine noise
    Hi
    I am new to biking and was wondering if anyone can help me
    i have a 1990 suzuki gsf bandit 250cc
    after a ride got back home and it just died was not starting had to wait for it to cool down then it started fine and running fine till it warmed up.
    once it was warm the engine noise was different didn't sound right and a ticking metal type noise coming from the engine. also once it is warmed up it would slowly start dieing and when adding abit of revs it takes a second or two for it the rev up almost like its struggling to get the revs.
    have added a video of it running with the sound
    appreciate any help that is given video0011.mp3VIDEO0011 (1).swf
    6th May 2012 - 10:41
    invisibike
    pulling a sick mono
    it's when they stop making noise that is the real worry.
    i'm picking coil packs, and valve clearances, and timing advance mech and carb sync.
    28th January 2015 - 16:17
    2000 Ducati ST2
    +1 to the above. I'd also add the cam chain tensioner to that list, also (long shot here) check your battery voltage and whether the charging system is still putting juice into the battery once the engine is running.
    Be methodical, go through things step by step, everything you can write off as "not the problem" is progress.
    17th April 2006 - 05:39
    Various things
    Quote Originally Posted by fullhouse View Post
    Hi
    The 4 cyl 250's are actually pricks of things, only the Honda's are ok. I'm thinking you'll need to do valve clearances.
    Quote Originally Posted by Crasherfromwayback View Post
    Correct in that most of them are pricks of things. The Suzuki is probably one of the worst. I'd ask first if it has oil in it - and if it overheated.
    I've actually got a GSXR250 here at present which is afaik, identical to the bandit, and the cooling system is very poor. Getting all the air out of it is damm near impossible due to the way the water passages go in the barrel. And it needs draining to pull the cam cover too as the outlet pipes go through the cover...
    Various things
    Yep. They're cunts of things.
