Results 1 to 5 of 5
Thread: 2004 GSX 250 Invader Carb/fuel problem
    24th January 2018 - 15:35
    Gsx250
    Paekakariki
    Hey all, first time posting
    So quick run down.. brought a 2004 gsx 250 invader couple of days ago. Original owner said he had it in storage for 3 years. He used start ya bastard on the filter to clean it and get the bike started, cleaned the carbs. Attempted to clean the carbs but didn't go so well. Anyway I bought the bike just took to the mechanics which cleaned the carbs fully , and also gave it a carb balance.
    The problem that started was the bike would become restricted/hesitant at 5000rpm till around 9000rpm then would carry on. After cleaning the carbs and the balance the problem still persists. After spending $230 getting it cleaned and balanced and checking spark plugs and some other bits and Bob's that were fitted incorrectly.
    The mechanic thankfully spent another 3 hrs trying to fix the problem by tuning everything and charged me a pack of 25 blue Winfield smokes . Any suggestions before I take it to another mechanic and waste my money that I don't have haha
    25th January 2008 - 17:56
    New Zealand
    Welcome along to KB.
    It seems that while you've got a willing mechanic, what you need is a slightly cluier one.
    Only one I'd suggest is running the bike with the fule cap open and see if it behaves as it should.
    If it does, you've got a blockage somewhere in the cap and it's unable to breathe and causing the bike to lean out and starve.
    Careful that you don't ring it's neck too long while ascertaing the problem.
    Good luck.
    31st March 2005 - 02:18
    CB919, 1090R, R1200GSA
    East Aucks
    Quote Originally Posted by caseye View Post
    You need to approve the post before anyone else can see it.
    6th May 2012 - 10:41
    invisibike
    pulling a sick mono
    been a while since this posted. start here:
    http://www.dansmc.com/carbs2.htm
    Gsx250
    Paekakariki
    Cheers dude, will give that a crack and see how it goes😊
