Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: ninja 250 oil filter and oil advise
    19th July 2018 - 18:28
    Ninja EX250 2008
    Manukau
    ya so i am going to buy ninja 250 that gonna need service , what sort of oil filter and oil do they use thats easy to buy from Auckland stores.
    28th May 2006 - 19:35
    suzuki
    lower hutt
    ninja 250's are available in 2 and 4 cylinders, and over quite a few years, you'll need to be more specific
    Ninja EX250 2008
    Manukau
    Quote Originally Posted by jellywrestler View Post
    2008?
    https://www.trademe.co.nz/Browse/Lis...?id=1679802938
    I found this ... hope it helps.
    If in doubt ... find your local Kawasaki dealer and ask questions .
    https://www.kawiforums.com/oil-lubri...rocedures.html
    Ninja EX250 2008
    Manukau
    but i cant find any of these filter to go with exninja 250
    Quote Originally Posted by Dharmbir View Post
    Try at a Kawasaki dealer then. THEY might be able to "FIND" one ...
    11th June 2011 - 16:30
    Honda vfr 750 fn 1992 x2 90red
    palmerston north
    oil filters its okay to get after market ones most bike shops will be able get you one of these and oil filter is a oil filter . as long fits your model .
    I have a 2006 or 08 i forget ninja 250 twin most common in a old 1988 ninja frame .
    palmerston north
    Nice bikes u be very happy with one of these great brakes easy to ride lots fun enjoy buddy wait till buy it and enjoy first
    U plenty time sort out the oil change and filter . just relax and enjoy the bike first.
    Its the the twin i rode twon up with pillion 100 kph no fuss up a decent size hill . no fuss
    Ninja EX250 2008
    Manukau
    Quote Originally Posted by actungbaby View Post
    ya i found k4n 401 on treadme hopefully they come with big and the small rings..and for oil Penrite mc-4 syn 10w-40 ,,gonna do it myself ..wish me luck
    Ninja EX250 2008
    Manukau
    ive done service on my ninja ex250 2008 today .. one question, when do i check oil levels a "running" ON bike or off bike? i mightve overfilled a bit..because when upright RUNNING ON bike oil level sits between low and high point but when i trun it off oil level goes above the high point
    1st June 2014 - 21:23
    Ducati 748R
    nelson
    motor off, bike upright.
    Ninja EX250 2008
    Manukau
    Quote Originally Posted by layton View Post
    im f'd then
    Ducati 748R
    nelson
    im f'd then
    drain it out READ A SERVICE MANUAL and get a measuring cup and put in what ever the manual says. easy fix, also check ur airbox because it probably blew oil into there if you overfilled it.
    Ducati 748R
    nelson
    Oil type: API SE, SF, SG, SH, SJ or SL with JASO MA.
    Viscosity : SAE 10W-40
    Capacity: 1.4 qt, or 1.7qt when filter is also replaced.
    Oil drain bolt: 14.5lb-ft
    Oil filter mounting bolt: 14.5lb-ft
    Oil screen mounting bolts: 7.25lb-ft (87lb-in)
    Frequency: According to the service manual, it's recommended that you change the oil filter every oil change, and oil change at every 7500 miles (yes that's seven thousand five-hundred miles).
    You do not need a rear stand for this, but it's highly recommended.
    * Warm the engine just enough for the oil to circulate freely.
    * Place oil pan under the bike to catch the oil.
    * Remove the drain bolt, and replace the washer if it's worn/damaged.
    * Remove the 5 oil screen bolts, 3 short and 2 long.
    * Remove the screen from the engine and clean it (many need to use a small flat head screw driver to pry it out)
    * Put the screen back into the engine, gasket on the screen housing, tighten the oil screen bolts, 7.25lb-ft.
    * Tighten both the drain bolt and oil filter to specs, 14.5lb-ft.
    * Remove and replace oil filter, 14.5lb-ft for the filter bolt.
    * Fill up the oil (1.7qt with oil filter replaced).
    * Done!
    Ninja EX250 2008
    Manukau
    well now that bike is cold the oil is just in line with high level,,you think i might be ok ?
