Results 1 to 6 of 6
Thread: Got KLR parts?
    2nd May 2017 - 12:42
    pig
    moonscape
    Got KLR parts?
    Looking for a few KLR bits and pieces:
    • KLR600 triple clamps/yokes
    • 1st gen (pre'08) KLR650 forks
    • KLR650 front wheel including rotor
    • KLR650 front brake (lever, cylinder, caliper, don't care about hose so much)
    Also interested in:
    • KLX650 triple, forks, front wheel, and front brakes
    • KLR250 KL250D rear wheel, or just rear rim, or compatible rim
    • KLR250 KL250D intake cams
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    I have a set of gen 1 forks. the triple has had the steering stem removed and the lock stops have been cut off (before i got them), also a brake rotor. Where are you located?
    (PostalDave on ADVrider)
    pig
    moonscape
    Well, good thing I don't really need a complete 650 triple. Can weld something on as lockstops if need be.
    I'm in Central Otago now, but in two weeks I'll be in Raglan for work until Christmas.
    Got any pics? What condition are your forks and rotor in?
    The rotor is well used but about 3mm thick (min thickness is 2.5) and appears to be unwarped.
    The forks appear to be straight and are complete, the bottom clamp has had the stem removed and the stops cut off. I dont have the upper clamp.
    If you are passing through on your way to raglan you can collect. Whatever you think they are worth (I like Emersons Porter)
    pig
    moonscape
    Okay, that sounds good.
    Hopefully but not guaranteed to be passing through on the way up, definitely passing through on my way back down before Christmas. Shall I message you a contact number?
    Quote Originally Posted by ashes View Post
    Yup, that would be fine.
